Old 06-25-2016, 09:04 AM   #1
asolde
asolde's Avatar
Electric fan
I have been running my Blazer 350 this summer 96* and when running my A/C the engine temp creeps upwards to 200* in traffic at a stop light. I don't like my engine to run much over normal operating temp 185*. I am curious about installing a electric cooling fan kit. What is your experience with that set up? Who has the best set up? I would like to buy a kit with everything that is needed to install it. Thank for any suggestions. Alex
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 06-25-2016, 12:06 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Electric fan
Nothing wrong with electric if that's what you want, but there's no need for it. You are a long way from overheating. Couple things to consider:
1. A stock cooling system, with everything in good working order (including a shroud & clutch fan), should never overheat.
2. Have you verified that your temp readings are correct?
3. 200* is far from overheating. Water boils at 212*, 50/50 antifreeze mix boils at 226* (unpressurized) and at 259* at 12 psi.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
