Old 06-25-2016, 09:37 PM   #1
65chevysub
65chevysub's Avatar
Steering coupler(rag joint) Install
Just bought a new rag joint for my Suburban, and was wondering how hard it will be to install? I noticed the bolt that clamps it to the steering shaft has a "serrated" pattern on the head. Is there a special tool I need to tighten it? Or should I change it to a standard, Grade 8 bolt?
Thanks for any help and or advice. I'm planning on replacing my old one tomorrow morning if I can.
65chevysub is offline   Reply With Quote
Old 06-25-2016, 09:48 PM   #2
cv65
cv65's Avatar
Re: Steering coupler(rag joint) Install
should be standard 12pt socket, soak it good tonight with liquid wrench etc.
cv65 is offline   Reply With Quote
Old 06-25-2016, 11:10 PM   #3
65chevysub
65chevysub's Avatar
Thanks. I forgot to mention the steering is a power unit out of a 72 Chevy truck. I don't need to remove the column and all that good stuff do I?
Old 06-26-2016, 09:47 AM   #4
vince1
Hopefully your spline counts and diameters are the same.
If you wanted to modify it to a collapsible shaft then of course more work would be required.
vince1 is offline   Reply With Quote
Old 06-26-2016, 11:43 AM   #5
65chevysub
65chevysub's Avatar
I'm leaving a standard column in it. I was just looking at my original and the replacement, and they look the same, but it looks like I'm going to have to take off the P/S box to change the joint. I can't tell about the spline count until I get the old one off.
Thanks for the tips.
Old 06-26-2016, 12:01 PM   #6
vince1
I can't remember for sure but it may be easier to slide the whole column up a bit if you need the clearance.
Old 06-26-2016, 12:54 PM   #7
65 C20
http://67-72chevytrucks.com/vboard/s...ight=rag+joint
Check this one out.
No need to remove steering box.
Will need to loosen steering coloum from dash and loosen where it goes thru fire wall.
Cal.
65 C20 is offline   Reply With Quote
Old 06-26-2016, 12:55 PM   #8
65chevysub
65chevysub's Avatar
OK. I will try that, or I will let a friend do it while it's in getting the lowering blocks installed.
Thanks again, vince
