06-26-2016, 11:08 AM | #1 |
Is this trim the correct length?
Is this correct? Or is this trim shorter than stock?
The bed trim looks a little short but the cab trim seems way short. |
06-26-2016, 11:51 AM | #2 |
Re: Is this trim the correct length?
This is factory trim on my 64 that I have been slowly working on to polish up. Your cab trim look same as mine, mine just looks pushed forward to the door just a tad more.
Both top and bottom bed trim on mine I moved so they were flush with front of bed so you could see the gap from end of trim to the bed seam. Your bed trim looks possibly less than a quarter inch shorter on the top trim and your bottom bed trim looks a little shorter than that if you had the fronts lined up the same. I bet it looks pretty darn good from 20 feet away, looks better than mine. |
06-26-2016, 11:57 AM | #3 |
Post Whore
Looks right to me, they never did the best job on making trim the right length or lining up just right.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
06-26-2016, 12:06 PM | #4 |
Thanks for you help and pictures. I feel a little better about it now.
This is some cheap junk trim I bought and did not do my research before purchasing. Last time I do that. |
