Old 06-27-2016, 08:59 AM   #1
jasnake65
another rear blinker question
Trying to figure out whats wrong with my RH blinker. I cant get that side to work and its frustrating...Grr. I did buy a new turn signal switch, a new blinker fuse(the one that makes the noise..lol) pop in a new fuse. Almost seems its still not getting the power to the turn signal for RH. LH works, brakes works on both sides. Is there a way I can check to make sure its getting power? Anyone have a quick diagram of the wiring colors?
When your checking the blinker switch connection under the dash what should I look for? Want to make sure Im doing it right
jasnake65 is offline   Reply With Quote
Old 06-27-2016, 09:59 AM   #2
bosephus
bosephus's Avatar
Re: another rear blinker question
When this happened to me it was a ground issue. I ran an additional ground wire to the frame. Hope this helped!
bosephus is offline   Reply With Quote
Old 06-27-2016, 11:12 AM   #3
jasnake65
Where abouts did you add? Be doing that tonight
Old 06-27-2016, 11:20 AM   #4
padresag
if the brake light works then you have a ground as brake light and t/s are the same element. is the brake light bright whan it comes on. you have tailights both sides?
ron
padresag is offline   Reply With Quote
Old 06-27-2016, 02:27 PM   #5
jasnake65
No blinker on the RH side only, blinker on LH only, have brakes on both
Old 06-27-2016, 02:31 PM   #6
padresag
you have already said that.
ron
Old 06-27-2016, 04:07 PM   #7
jasnake65
Just got home, tail lights on, blinker works, brakes work on LH, no RH blinker. I switched wires and can make the RH blinker work when I turn LH blinker. This makes believe no power getting to the actual switch. That point I am stump to what to look for
Old 06-27-2016, 05:28 PM   #8
jasnake65
I did forget the steering column is a 63-66
