Old 06-27-2016, 12:04 PM   #1
DangerDan
Step Side fender interference
I need to figure out how to get fender clearance. I just test fit my step side bed and it hits the tires before I get it down to the bed mounts. Anyone have info or pics on how they flared their fenders?
DangerDan is offline   Reply With Quote
Old 06-27-2016, 12:19 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Step Side fender interference
Have you already cut the lip out on the inside of the fender? I would start there. I left about 1/4" of the lip so the fender wouldn't flop around on my '69. Plus, if you cut some of the lip out, the fender will be much easier to roll if you decide to flare it some.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-27-2016, 01:12 PM   #3
cdowns
cdowns's Avatar
you could use the old tried and true metod of rolling it out with a baseball bat
Old 06-27-2016, 01:22 PM   #4
Hardworkinguy
Roll it out:
https://www.youtube.com/watch?v=RUv9YPd_0Zc
https://www.amazon.com/ARKSEN%C2%A9-...Y0C262D29MX756
Hardworkinguy is offline   Reply With Quote
Old 06-27-2016, 01:38 PM   #5
BC10
BC10's Avatar
Wow, there really is a tool for everything!
BC10 is offline   Reply With Quote
Old 06-27-2016, 02:49 PM   #6
DangerDan
Thanks Guys I need to move them out a BUNCH, like 2 to 3 inches, the flange isn't going to be enough. I think I need professional help ( in more ways than one), probably save me money in the long run.
Old 06-27-2016, 04:50 PM   #7
54belair
54belair's Avatar
I think you might be down to changing the amount of spring drop or changing wheel size. Im running 17"'s with a 4" drop and Ive got a ton of space left over (?).
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 06-27-2016, 05:17 PM   #8
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Agree here, the wheel is the wrong offset, you must have 2 inches inside.
Don't cut the fender you will hate yourself later.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 06-27-2016, 05:29 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Wrong backspace on your wheels....
LockDoc
Leon
Old 06-27-2016, 06:02 PM   #10
Grumpy old man
Grumpy old man's Avatar
Don't flare the fenders ,don't cut them ,don't roll them with a bat , do it right and change the rims .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-27-2016, 07:14 PM   #11
DangerDan
Yeah I think you are all right, I do not want to cut the fenders. I am running coil overs and a 4 inch drop. I bought 20 X 10 for the rear 20 X 8 inch for the front first build not my first mistake. Nice rims too. I can't offset there is only about an inch clearance on the inside.
Old 06-27-2016, 07:26 PM   #12
DangerDan
Anyone ever widen the bed by adding material to the front panel? To move the fenders out? I have to raise the bed 4 inches to accommodate the rear rail kit I put on so I could trim the side panels to clear the inside of the tires...thinking out loud here....
Old 06-27-2016, 08:00 PM   #13
54belair
54belair's Avatar
Widening would be tough. Now with that said, Ill also say that ANYTHING can be done, but---- if you widen the front panel, youll have to widen the rear panel and youll have to widen all the bed to frame braces. And add one more bed floor pc. and strips. After all that work Im afraid it will look like youre driving a dually.
Remember one of my fav. sayings: You can save yourself into the poor house!
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
Old 06-27-2016, 09:03 PM   #14
BossHogg69
motor exploder
BossHogg69's Avatar
10" wide rims on a lowered stepside are a no go without some cutting. You could open the can of worms of narrowing the rear end, but then you're still going to have to tub it on the inside. I put my truck up on the lift today and got some pics for you, but if you're talking 2"+, trimming the lip won't get you anywhere. Good luck on whatever you decide.
Adam
Old 06-27-2016, 09:14 PM   #15
1978chev
If I remember correctly I am running a 20x8.5 on the back of my step
I believe it's 5.5 backspacing fits real nice and I'm 6" drop in back
1978chev is offline   Reply With Quote
Old 06-27-2016, 09:15 PM   #16
Mike C
Mike C's Avatar
I didn't do anything to mine. But spent hours calculating and estimating clearance. On my '69 I swapped to the wider rear and ran a 17x9 rear wheel with 5" backspace (zero offset) and 275 55 17 tire. Fits great, looks great IMO.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-28-2016, 08:57 AM   #17
DangerDan
i definitely screwed up, guess I'll buy another set of tires and wheels! Thanks for the help!
New Tires and wheels for sale !
Old 06-28-2016, 09:10 AM   #18
Mike C
Mike C's Avatar
What axle is in your truck? If the wider housing you could get a narrow housing and 5 lug conversion axles. THen if offset in too much you could add a small spacer.
Not sure how expensive your wheels are, but that is the easiest way to go for sure.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-28-2016, 10:00 AM   #19
DangerDan
It is the chevy 12 Bolt Posi trac I already have the Chassis done I have rebuilt the axle. Matter of fact I have replaced all the bearings in the truck. i don't really want to alter the axle. Just going to bite the bullet and get different wheels and tires.
Thanks for the input though.
Old 06-28-2016, 10:06 AM   #20
GR8-68
GR8-68's Avatar
I have seen quite a few make the mistake of thinking the stepsides have more room for more tire, I used to think the same but it is actually the opposite of that. The cheaper and easier way is to change out the wheels at this point
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 06-28-2016, 05:35 PM   #21
Mike C
Mike C's Avatar
What year is your truck? Just curious because that was a major consideration for me when fitting tires/wheels. Not sure if you know, but the 67-early 70 housings are narrower than the late 70-72 housings. If someone converted your truck to discs/5 lug they might have used the narrow housing but if it's a factory 5 lug it would be wider. If the wheels are $500 each, the axle housing/5 lug swap would probably be cheaper. But if wheels are less than $150 like mine, then obviously that's the way to go.
But to make my wheel/tire combo fit the wider axle was the only choice based on the backspacing available on the wheels I was willing to $$$.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-28-2016, 07:45 PM   #22
DangerDan
It is a 71 I bought Ridler wheels so they we not to bad. Pretty much resigned myself to buying wheels and tires. Thanks for the input.
Old 07-08-2016, 02:38 PM   #23
DangerDan
Thanks everyone, I received and installed the new wheels and tires today. Just had to stretch the right front inner fender a little and cut away a little to clear the shock towers. New thread starting on how to properly raise the bed 4 inches.
