Old 10-01-2003, 09:53 PM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Darn Oil Pressure Line!!!!
So the Line busted again on my girls 63......Probably cause I re-used the fitting and stuff,,,so it didn't work and just cut the line...it held up for a day. Bought the whole line setup at AZ.....gonna have to do it tonight with some lamps cause I got class tommorrow and my girls has to go out of town tommorow morning!!!!
TIME FOR SOME COFFEE!!!!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 10-01-2003, 10:21 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Make sure you use the copper line it seem's to hold up the best or the braided line work's well too.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-01-2003, 11:21 PM   #3
Hooter
My other Love
Hooter's Avatar
make sure you tighten properly, or else you will have a mess of oil in your carpet that will never seem to come out.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-02-2003, 02:23 AM   #4
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Ditto Hooter on the oil mess on the carpet..........my guage in my 'vert leaks. ack
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 10-02-2003, 02:47 AM   #5
Southpa
Southpa's Avatar
Thats reminds me of the time I had a loose fitting going into the oil pressure gauge. And there was a very slow drip...right onto the gas pedal. Thats one of the strangest sensations I've ever encountered. My foot kept slipping off the pedal!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 10-02-2003, 06:17 AM   #6
Lippyp
English Chevy Owner
Lippyp's Avatar
I was driving a Ford Transit Van (UK Model) at work a few years back when my foot kept slipping on the uncarpeted floor, I thought someone had spilt some oil on it, until I put my hand down and felt the heat! It turned out the exhaust was blowing straight onto the floor pan (I was screaming up the motorway (freeway) at the time and it was actually the soles of my shoes melting on the floor making them slip!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-02-2003, 01:04 PM   #7
70 longbed
Is there a new aftermarket line to go from the block to the line that goes to the pressure guage. I am referring to the one that is coiled for vibration. Also what about the line from the guage that exits the firewall?
Keith
70 CST longbed in progress. Hoping to get it back on the road soon.
70 longbed is offline   Reply With Quote
Old 10-02-2003, 07:43 PM   #8
JimKshortstep4x4
Smile
70 longbed,
Paragon has them. Try this link. I would suggest getting their catalog as it is a nice wish book and there are other parts that you may be looking for in the catalog.
Jim
http://www.corvette-paragon.com/
Old 10-03-2003, 12:14 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
I got the copper one from O'Reilly's. I beleive that Auto Meter is what brand it was.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-03-2003, 12:49 AM   #10
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I broke the copper & the plastic lines. The vibes will eventually break off both. I got a couple of -3 to pipethread adaptors & a pre-made section of -3 line from summit (russell i believe). It will last forever, look cool & never give you grief. The guy on the phone @ summit said that they dont have the premade lines in the catalogue but they still stock it. Measure how long u will need (remember that braided line cant make tight turns...), get the right adaptors for -3 to what ever size pipe thread that you have on the back of your gauge & at your engine, pipe dope it up & its done for good. No copper to break & no plastic to melt/break. Just one mans opinion but it is too critical an area for jobberjoe stuff.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-03-2003, 01:45 PM   #11
Firefighter
Well if you have a problem with breaking the copper line, then try this: Get a piece of rubber fuel line or vacuum tubing that will just fit over the copper line then slide it over the copper line and then you should be able to bend the coil spring shape in the line to reduce shock in the line without kinking it. Then just place your fittings on the ends of the copper tubing and hook it up. The rubber hose will absorb the vibrations and keep the line from breaking. I have have had mine on my GMC for 14 years with it setup that way and have never had a problem.
Yellville, Ar. USA
