Old 06-27-2016, 05:58 PM   #1
Afirehawk1
66 c10 lower ball joint seal
Stupid question. Does ball joint seal get pressed on at same tim from bottom or get pressed on from top after ball joint on?
Afirehawk1 is offline   Reply With Quote
Old 06-27-2016, 11:13 PM   #2
racecougar
racecougar's Avatar
Re: 66 c10 lower ball joint seal
It goes on from the top after the balljoint has been pressed into the arm.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 06-28-2016, 07:50 AM   #3
Afirehawk1
oh good. i thought so. does the spindle hold it in place? wasnt sure how far on the ball joint that the dust boot sits on.
Old 06-28-2016, 10:58 AM   #4
racecougar
racecougar's Avatar
Once the spindle is installed the boot won't be able to fall off of course, but it should be well seated at the base. Some of the cheaper balljoints/boots don't fit together too well.
