Old 10-01-2003, 10:05 PM   #1
Iron-Butt
454 club
Iron-Butt's Avatar
steering column swap
Here is a picture of the two different plugs. is there an adapter? the wires are not the same color. is there a easy way to change.
the two piece plugs was to my original non tilt 3 speed column. the one piece plug is to the tilt automatic motorhome column from a 67.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-02-2003, 03:18 PM   #2
Iron-Butt
454 club
Iron-Butt's Avatar
ttt
David
Old 10-02-2003, 07:24 PM   #3
JimKshortstep4x4
Smile
I don't know of any adapters, but if it were mine I would splice each wire together, solder, shrink tube wrap each wire, and then tape. It looks like the wire colors are all there to keep it straight.
Good luck!
Jim
Old 10-02-2003, 08:13 PM   #4
Iron-Butt
454 club
Iron-Butt's Avatar
Does any one have the wiring diagram for the column so that I can splice the wires correctly as they are different colors.
David
Old 10-02-2003, 08:13 PM   #5
68 Stepside
huh?
68 Stepside's Avatar
I believe you can get the adapters at your GM dealer. Someone here probably has the part number as well.
TTT
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-02-2003, 08:14 PM   #6
Iron-Butt
454 club
Iron-Butt's Avatar
I tried at the Chevy dealership today with no luck.
David
Old 10-03-2003, 12:24 AM   #7
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
The only adapter that I have seen was for the plug in the left hand side of the pic. It has the U shape on one end and a flat plug on the other, it is for a later model tilt that have all flat connectors. It allows you to use the original under dash U shape plug with the flat style. I don't guess I have ever seen the two piece plug that you have.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-04-2003, 12:05 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The fact that your tilt came from a motorhome is what is making everything goofy. If you were to get a van one, then you could get an adapter at the dealer no problem.
What year/make was the motor home?
Old 10-05-2003, 11:36 AM   #9
Glen
check with ididit columns, I just threw an adaptor in the trash last week. I swapped in one of their columns, shafts, and eliminated the rag joint with u-joints.
Glen is offline   Reply With Quote
