Old 06-27-2016, 09:11 PM   #1
Bandit130
Bandit130's Avatar
OEM Steel Fan Blade Spacer
Wondering if there are any fan blade spacers for 19" OEM steel fan blade with mechanical clutch? Has shroud. Wanting to set blades a little more into shroud for better air draw to help with AC cooling. I have found several that appear to be for flex fans, but have not seen any for steel blades.
74 C10 350/350
TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 06-28-2016, 10:11 AM   #2
tucsonjwt
Re: OEM Steel Fan Blade Spacer
I am not sure exactly which size you are looking for, but the auto parts stores have fan hardware kits which include bolts and spacers. I got mine from AutoZone when I replaced the fan clutch on my C20 454. Also, my local Ace Hardware has a selection of aluminum bushings which will probably meet your needs.
tucsonjwt is offline   Reply With Quote
Old 06-28-2016, 10:46 AM   #3
Bandit130
Bandit130's Avatar
I have seen several. Most all of them specify for flex fans. Will the aluminum spacers hold up for steel fans without any issues? There is a weight difference.
Thanks.
Mopar by Birth
Chevy by Choice
Old 06-29-2016, 12:04 AM   #4
ron350
ron350's Avatar
If you are asking what style spacers Chevy used see the picture.
My 75 C10 came with a 350 two barrel carb and no AC. The truck came with a fixed fan and a 2-inch long aluminum spacer and sounded like an airplane going down the road.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 06-29-2016, 12:24 PM   #5
tucsonjwt
What size spacers are you looking for? The ones I got from AZ were about 1/2" long, as I recall. But Ace Hardware has many different lengths. I would try Ebay or Amazon if you have a particular spacer in mind.
Old 07-03-2016, 08:43 PM   #6
Pontiac1976
Pontiac1976's Avatar
Hello. Can you post a pic or two from the side showing your fan and clutch fan and far it's from the shroud.
Is that your factory fan clutch it was set up with?
How many blades does your fan have?
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
