Old 06-28-2016, 02:11 AM   #1
WILD WILL
Advice? Help!
Hey y'all, I got a 93 chevy4x4 ext 5spd truck. She Was runnin like a champ. Had noticed the oil sensor switch behind distributor was loose so went to tightin it up. In doin so I cracked the distributor cap. Bought a new one along with plugs. (ac Delco) new pcv valve, n new rotor. Put it back together. Set timin n she is runnin like crap. No power, when I put pedal to floor it falls on its face, bogs, backfires. When jus idling in neutral sounds great. Rev engine no problems only when drivin. Plz help y'all. Been workin on truck for 3 days now. Lost on what to do.
WILD WILL is offline   Reply With Quote
Old 06-28-2016, 12:44 PM   #2
sntrym95
sntrym95's Avatar
Re: Advice? Help!
Did you set the timing with the timing connector disconnected? If not, then you'll need to do that first.
Mike
sntrym95 is offline   Reply With Quote
Old 06-28-2016, 01:09 PM   #3
OutlawDrifter
Re: Advice? Help!
what's the status of your fuel filter?
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 06-28-2016, 01:09 PM   #4
WILD WILL
Re: Advice? Help!
Yes sir I did. In process of redoin the whole process.
Old 06-28-2016, 01:10 PM   #5
WILD WILL
Re: Advice? Help!
Fuel filter, pump n regulator is new.
