The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
5 lug to 6 lug
Have 5 lug discs on the front- what is involved in converting to 6 lugs?
Thanks Dave
Dave 69 GMC SWB 2WD 454 Turbo 400 |
Re: 5 lug to 6 lug
I believe u would need to change out the spindle, hub assembly. But I am not certain. Tht is a job I have avoided on another truck of mine. due to story's iv been told. Lol. Wish ya best of luck. Lemme kno how it turns out bud.
![]() Join Date: Jun 2009
Re: 5 lug to 6 lug
6 lug disc's are available I am sure, that would be the easiest option
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Re: 5 lug to 6 lug
Just the rotor and the wheel would be different.
But if it is a 6 lug drum truck you want to put a 71-72 disc setup on you will need change ball joints and tie rod ends again.
![]() Join Date: Sep 2007
Re: 5 lug to 6 lug
6 lug rotors from our vendors will slide right on to 71-72 spindles. just specify what you want to do when ordering. i used mcgaughys
1967custom |
Re: 5 lug to 6 lug
That is the info I was hoping for.
Will get the new rotors ordered and swap them out. Saved me a ton of time, money and worry. Thanks, guys!
| Bookmarks |
