Old 06-28-2016, 03:15 PM   #1
jtinpdx
Back end comes around under panic braking.
Hi All,
I can't keep my truck straight under hard braking. The backend comes around really aggressively. It's a 71 with power brakes in the front and drums in the back. Longbed. Posi-traction. It also has a trailer assist brake installed.
The brakes have been inspected and pads replaces recently. New master cylinder also.
Any ideas about what to look for?
Thanks,
Jeff
jtinpdx is offline   Reply With Quote
Old 06-28-2016, 03:50 PM   #2
GRX
GRX's Avatar
Re: Back end comes around under panic braking.
Did you set the pin on the combination valve?
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 06-28-2016, 05:15 PM   #3
RustyBucket
RustyBucket's Avatar
My '71 GMC did the same thing, rear end always came around to the right. R.R brake adjuster was was stuck. Freed it up, adjusted drums and it'll lock all four and stop pretty straight now.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 06-28-2016, 08:40 PM   #4
jeffahart
jeffahart's Avatar
The rear brakes are not coming on. It's the rear brakes that keep you straight when you brake. So I would check the metering block. I am assuming you have disc front when you say power front. So you would need a metering block. Metering block holds pressure off the discs a bit until a certain pressure. But the 71 might have a combo valve. Anyhow I would verify correct parts and setup. Someone could have changed some brake components.
White K20
jeffahart is offline   Reply With Quote
Old 06-28-2016, 08:56 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Are the rear drums locking up? Could have gear oil leaking past the outer axle seals and if it gets into the drums it makes the shoes stick to the drums when the brakes are applied.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-28-2016, 09:21 PM   #6
Chknlyps2
Find a dirt road or parking lot that is level, go about 10 mph or so and hit the brakes hard enough to skid to a stop and park right there. (Looseness of the dirt/ traction will dictate speed.) You want to get out and see which front brake locks up first, if you went to fast your back tires will pass up where your fronts engaged and erase the starting point of the fronts. If both start to skid close to the same place then go a little faster so you can get the rears to lock up and see if they both start skidding at the same place. You can rule out or confirm a non working wheel or whole axle this way.
Chknlyps2 is offline   Reply With Quote
Old 06-28-2016, 09:51 PM   #7
old Chevy guy
old Chevy guy's Avatar
I'm no expert and I don't play one on tv either but I remember in my younger days we used to jerk up on the parking brakes in our cars and spin them around 180 degrees. I'd be thinking rears are locking and fronts not so much. Try that dirt road skid suggestion that will tell you what's going on.
old Chevy guy is offline   Reply With Quote
Old 06-29-2016, 08:59 AM   #8
Rich69shortfleet
How do you do this?
Rich69shortfleet is offline   Reply With Quote
Old 06-29-2016, 02:57 PM   #9
jtinpdx
Thanks for all of the suggestions, guys. I have some research to do. I'll do the skid tests and let you know what I find.
As for the prop valve, yes I think it's the right part and has been set. The dash light does not go on, and I know the dash light works. The reason I have a new master cylinder is that the light was always on. The master cylinder was leaking out of the one of the pistons, not sure which. That was replaced, and I assume the prop valve sender was reset, since now the dummy light isn't on.
But worth checking.
But that's why I mentioned the trailer brake assist. There's a brake line splice off of the rear brake line for the trailer assist. I wonder if that isn't causing some issues. I plan to remove it. I should do that now and see if it helps.
Old 06-29-2016, 03:21 PM   #10
kwmech
Air still in the system after the MC swap?
Old 06-29-2016, 03:33 PM   #11
Grumpy old man
Grumpy old man's Avatar
What ? You mean your almost 50 year old truck didn't come with ABS . Heaven forbid !
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-29-2016, 03:42 PM   #12
ga-stepside
ga-stepside's Avatar
LOL. In 1993 I bought my first truck with ABS and two weeks later I had a major panic stop and was amazed to see ABS actually works!
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 06-29-2016, 03:49 PM   #13
Grumpy old man
Try the same truck in ice and see how that works for ya ?
Old 06-29-2016, 05:28 PM   #14
ga-stepside
Nothing works on ice but experience. Been in Georgia for 27 years and have probably lost my snow and ice driving talents!
1967 C10 Step side
1970 AMX 390
