Old 06-28-2016, 06:03 PM   #1
oliver63
oliver63's Avatar
sway bar/lower control arms
I have a '63 c10 that doesn't have a sway bar. I bought a sway bar kit from CPP. There isn't any place on the lower control arms for the sway bar links to bolt up. Is there a bracket for the sway bar links to mount to or is there a hole in the control arms? Pictures would really be appreciated!
1990 Silverado Sport
2010 Silverado K1500
1996 K2500
oliver63 is offline   Reply With Quote
Old 06-28-2016, 07:27 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: sway bar/lower control arms
Most of the front sway bar/OE lower control arm combinations that I've seen look similar to the photos below (bushing bracket bolted to the lower control arm). I have seen some where people bolted or welded an "L" bracket to the leading edge of the lower control arm for the bushing mount.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-28-2016, 10:42 PM   #3
dracko
dracko's Avatar
You could bolt up the swaybar to the frame, centred, line up your brackets and mark where the holes need to be drilled for the end links.
dracko is offline   Reply With Quote
Old 06-29-2016, 08:16 AM   #4
oliver63
oliver63's Avatar
The sway bar I have is different than the one in the pictures above. My has the link bolt with bushings. Mine is like a factory type. I am trying to figure out where the link bolt is in the factory position. I guess my truck being a '63...they must not have come with a sway bar on any of them.
1996 K2500
Old 06-29-2016, 10:00 AM   #5
Backpayne
Looks like you will need an L-bracket based on this picture:
https://www.google.com/search?q=c10+...CTUwvHJJW8M%3A
Backpayne is offline   Reply With Quote
Old 07-20-2016, 08:31 PM   #6
canadian_diesel1964
Sorry to interject Oliver63 mine is also a 63 with no holes..do you guys happen to know how far through the bushings on the control arm the ends of the sway bar go? That would be towards the back of the truck...I figure if I can set the depth then I can measure for the holes...it's a 73-87 sway bar like the first picture with early classic lower brackets and poly bushings. Thank you in advance.
canadian_diesel1964 is offline   Reply With Quote
Old 07-20-2016, 08:52 PM   #7
dracko
dracko's Avatar
My truck is stock and I think they stick through about 2"
Old 07-20-2016, 09:14 PM   #8
canadian_diesel1964
Thank you !
Old 07-20-2016, 10:18 PM   #9
dracko
dracko's Avatar
Ya no prob, I can double check in the morning just workin tonight.
Old 07-21-2016, 12:04 AM   #10
canadian_diesel1964
That would be great thx
Old 07-22-2016, 12:36 AM   #11
dracko
dracko's Avatar
Okay I double checked. I recall the bar sticking through about 2" but that was with some weight off the wheels so I could get the brackets bolted on. Fully compressed the bar sticks through 3/4"-1" on each side.
Old 07-22-2016, 08:49 AM   #12
curvedglass
curvedglass's Avatar
I installed the cpp front bar on my 63. I mounted like explained above. centered it on the frame and marked holes as if I were mounting the 70's style right to the a-arm. I marked and drilled the holes and I used the rubber link bushings top and bottom with a new shorter grade 8 bolt from Ace Hardware. None of the spacers were needed.
I installed both front and rear sway bars and what a difference. I have about 3000+- miles on them and no issues. Kind of trip shifting the 3 speed in the S turns.
--Life looks better through a curved windshield--
curvedglass is offline   Reply With Quote
Old 07-22-2016, 10:28 AM   #13
oliver63
oliver63's Avatar
Thank you for your reply...i got it on and it turned out really good. Now...if I can ever get my brakes bleed to where I have a good pedal...i will try out the sway bar.
1996 K2500
Old 07-22-2016, 11:50 AM   #14
curvedglass
If you were switching to the CPP power disc brake kit I can tell you that your pedal will never be as tall as manual breaks. As long as you were confident that you removed all the air from the lines it will stop on a dime
Old 07-22-2016, 01:19 PM   #15
oliver63
oliver63's Avatar
I went with four wheel disc brakes with a non-power master cylinder. I haven't drove it yet...but the low pedal is not very exciting.
1996 K2500
Old 05-26-2018, 09:42 PM   #16
Ken Cook
Ken Cook's Avatar
I had a low peddle on my CCP brake upgrade until I bought it to Meineke and had them bleed the brakes. Now I have a normal peddle and great brakes.
Sorry I just realized this is an old thread.
Ken Cook is offline   Reply With Quote
