Old 06-29-2016, 10:31 AM   #1
spudz
spudz's Avatar
Picked up a Suburban.....questions about rear flip kit
I just picked up a 91 suburban. I want to static lower it, flip kit in rear, springs and spindles up front. My question is, do I need a c-notch in the rear? I cant find any kits specifically for suburbans from any of the big names. I know I can use regular c10 stuff in the front and I assume c10 flip kit will work in the rear. But will I need a c notch? I know a c10 c notch wont work. Does anybody make a bolt in c notch for a suburban??? I have a dozen square bodies and have had a ton of them but this is my first burb. Ive searched here and google with very little to go by. Ive found suburbans that have had a flip kit done so I know its possible.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 07-01-2016, 04:09 PM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Picked up a Suburban.....questions about rear flip kit
It's possible fore sure. Mine has a flip kit and no notch. I have a bolt in c-10 notch for it but haven't installed it, probably gonna 4 link it next year and do that at the same time. I'd recommend doing a flip kit and at the very least, install air shocks. Just to be able to give yourself some room for travel when hauling or towing. Air shocks and a flip kit got me by for a year until I went with full air ride.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 07-04-2016, 10:35 PM   #3
bbbc10
Diggin The SquareLife
I doubt the c10 notch will work.....gonna have to look for a universal weld in one
bbbc10 is offline   Reply With Quote
Old 07-14-2016, 08:50 PM   #4
Koz1
1. look for a straight c notch,like one for 92-99 burb's ,also get thick as possible,weld in,since you can't really access top of frame for extra bolt's,maybe even put a plate on the inside of frame?
2. If you need to raise rear some,you can use stock c-10 type front hangers,since burb hangers are all-ready lower,or simple move the stock hanger down some,.75 or so.
3. pick up some shock extenders,longer shock smoother
4. Leave the 5th leaf- overload in,or go three leaves with AOL.
Koz1 is offline   Reply With Quote
