06-29-2016, 02:24 PM | #1 |
How can I tell...
My truck is a 49 but I do not know if it is late or early. I need to get a headliner for it and they make two different ones from what I can tell online.
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
06-29-2016, 03:23 PM | #2 |
Re: How can I tell...
Early 49 trucks have the windlace held in by a metal strip with screws while later 49 trucks have a metal channel around the door opening that the windlace is inserted in to.
07-01-2016, 04:26 AM | #3 |
07-01-2016, 10:01 AM | #4 |
I had the same issue and called and talked to the guys at Classic Parts. They said there can be differences in the late and early 49s dependent on where it came of the line. I was told the early 49 has screws down the center that holds the center bow on. The late doesn't. If you look at the pics on their site you can see screws / no screw.
47-Early 49 here: http://www.classicparts.com/1947-49-.../#.V3Z2wvkrJhE Late 49-53 Here: http://www.classicparts.com/late-194.../#.V3Z28PkrKM8 Mine has a metal channel for the windlace. So...mine had early and early 49 headliner and a late 49 windlace. Makes it fun figuring out what fits. |
07-03-2016, 07:04 AM | #5 |
Thank you all that sure did and help. I like buying things from Classic Parts.. Maybe to much at time.
07-03-2016, 03:29 PM | #6 |
Here is a pretty good breakdown on year to year changes on AD trucks
http://www.adchevy.com/info/yeartoyearchanges Here is another one that has some extra info http://devestechnet.com/Home/History
07-03-2016, 07:16 PM | #7 |
I took a picture of the the area above the door... Can you tell if it is an early or not? I look at the roof and it looks like it has a rail that goes across with screws in it. My truck may be a hodge podge as the person before me took 2" out of the roof.
07-03-2016, 08:26 PM | #8 |
well, to be fair, they will all have screw holes in the roof support. what Hussey was talking about though was the center bow of the headliner. if its early 49, the exposed part of the bow will be smooth and the screws will actually be in the back part of the bow, that will be covered by the next piece of the headliner. if its late 49, the screws will be in the exposed part of the bow.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
07-03-2016, 08:56 PM | #9 |
Is the top chopped and stretched on that one?
It is a late 49 as far as the channel on the right hand side of the photo goes but from where the roof is spliced back they have goobered the channel up pretty bad. I won't get home from work until 7:30 Pacific time but I'll try to get some photos of that area of two cabs I have so you can see the difference.
07-04-2016, 12:50 AM | #10 |
This is the retainer strip in the early 49 cab I have you can see the strip and if you look close you can see the screws holding it and on the right you can see a bit of headliner behind it.
A little closer shot of the middle of it. Here you can see how the molded rubber windlace fits in the channel in the late 49 and later trucks here is the strip that runs though the middle of the roof and holds the headliner in the middle on the later trucks. Note that it is welded in rather than held by screws like the earlier version
07-04-2016, 12:53 AM | #11 |
Looking at yours again I think you have the early 49 and someone took the front half of the strip off when they worked on the roof.
07-04-2016, 08:57 PM | #12 |
great post
. . .......................Sp . . .. .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
07-07-2016, 05:11 PM | #13 |
Here are a few more to look at. I hope this will let it be know if it is early or late 49.
07-07-2016, 05:48 PM | #14 |
It's a early 49.
07-07-2016, 06:34 PM | #15 |
Thank you... What a great place to learn from.
