06-29-2016, 02:39 PM | #1 |
1971 Chevy pickup cooling problem
My 1971 pickup is having cooling issues. Its from Arizona and has a large aluminum radiator with an electric fan on it. The fan died. I was wondering if I just put a regular fan driven by the water pump pulley would that be enough? I live in upstate New York so tremendous outside heat is not an issue. The pump sits 9 inches from the radiator. Any and all suggestions for this problem are appreciated.
06-29-2016, 04:20 PM | #2 |
Re: 1971 Chevy pickup cooling problem
If you go with the stock fan get a fan shroud too or it won't work at all. Make sure the fan is inside the shroud about 1/2" or a little more. Again if its outside the shroud it won't work very well.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
06-29-2016, 06:59 PM | #3 |
thank you
06-29-2016, 09:09 PM | #4 |
I live in upstate ny too I also have an aluminum rad no shroud and just a 4 blade fan no clutch it cools just fine
06-30-2016, 03:37 PM | #5 |
I've got a 71 GMC and recently switched to an electric fan. It cooled OK with the stock fan and no shroud even here in Texas, but I switched because the constant drag of the pulley driven Fan on the motor.
My electric fan setup has two fans. I even disconnected one of the fans and its still cools just fine in the heat with full AC running. I would recommend replacing the electric fan because my motor revs easily now. In short, it has noticeably more high end power.
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali Last edited by Thundarr; 06-30-2016 at 03:59 PM. |
06-30-2016, 04:18 PM | #6 |
sorry
1971 GMC C15 Sierra Grande SWB 1972 Chevy C10 Custom Deluxe LWB 2018 GMC Yukon Denali |
06-30-2016, 04:20 PM | #7 |
triple post
06-30-2016, 06:33 PM | #8 |
You might be able to run just a fan up there. I grew up near Jamestown... it flat out does not get hot there...
*IF* you run a fan only, it needs to be spaced 1" from the radiator, otherwise it won't work well. If you do use a shroud, the fan just needs to be about 1/2 in / 1/2 out, spacing from the radiator doesn't matter.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-01-2016, 07:49 AM | #9 |
thanks a ton guys!!!
07-23-2016, 05:21 PM | #10 |
you can, but make sure to use a shroud as it will make a lot of difference on that application.
07-23-2016, 05:28 PM | #11 |
If you've already got the relays, temp sensor, and everything else for the electric, I'd just replace the electric, as a good fan, shroud, and clutch will add up.
