Old 06-29-2016, 06:19 PM   #1
Mgicm
Explain battery & alternator voltages please
I feel like im not fully up to speed so going to ask some basic questions on a 73 gmc with 350 engine.
1. Brand new battery reads 12.65v with truck off. When truck is running, i see 14.4v being sent to battery. Come back next morning, battery at 12.5 volts. Is this as expected? Or should battery be holding 14.4v? Or might something be draining overnight. I dont think it is draining overnight as right after i shut off it is about 12.6 and about the same the next morning but have to test more.
2. Had a few incidents where truck would not start after driving for 30+ minutes. I thought it was a hot start issue but might not be. Truck started fine, drove 30 mins and shut off. Came out 15 mins later and nothing. Sat for 3 hours and still nothing. Battery showed 12.5v. Got a jump off another car and started the truck like it was not even an issue. But it starts in the am cold with 12.5v. Totally puzzled.
Battery was brought back to store and checked to be good. no issues with that. Alternator is 2 months old and seems to be ok as i see the 14.4v when running.
Mgicm is offline   Reply With Quote
Old 06-29-2016, 06:26 PM   #2
wfojon
Chevy guy
Re: Explain battery & alternator voltages please
That is how they work, the battery is 12 volts and while running and alt puts out 14+ and that powers the truck not the battery.
You probably need a new starter, I just replaced mine for just that reason. When it got hot the starter wouldn't work but when cooled off it worked just fine now the heat doesn't bother the new one.
Jon
Tehachapi, Ca
57 BBW shortbed
64 C30 service bed
65 C10 long bed fleetside
70 C10 long bed fleetside
74 C30 flatbed
wfojon is offline   Reply With Quote
Old 06-29-2016, 06:32 PM   #3
jjzepplin
jjzepplin's Avatar
Check grounds on cables. Etc. Cable clamps are also notorious. Spend a few extra bucks and get some good ones. Stuck at the grocery store with melting goods is worth a few bucks eh.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-29-2016, 06:34 PM   #4
Mgicm
Jon
That happened 2x. But now the last time it would not start after 3 hours without a jump. Could it still be a starter issue. It is old.. i will say that.
Are ministarters better in some way than the direct replacement?
thanks
Old 06-29-2016, 08:47 PM   #5
wfojon
Chevy guy
I bought the life time warranty Napa starter for 49.99 and my old one as a core. You can't hardly beat that for piece of mind.
Tehachapi, Ca
57 BBW shortbed
64 C30 service bed
74 C30 flatbed
Old 07-01-2016, 03:53 PM   #6
'76 Big Block
You might check wiring going to the starter solenoid for loose wires/terminals, etc.
Sounds to me as if you may have a bad solenoid, but then, several things can cause the type problem you're describing, ( such as a worn neutral switch).
I'm running headers on my 454, and once they heat up, when I go to restart it, the starter will hesitate/turn slow, but usually comes up to speed after that----fortunately, mine's tuned pretty good, so starting is never a case of having to turn over more than once or twice....
'76 Big Block is offline   Reply With Quote
Old 07-01-2016, 04:08 PM   #7
Wgesnerjr
Wgesnerjr's Avatar
I once had this problem on an old Catalina. Turned out the positive cable on the starter was loose. didn't realize it until I was watching it start up with the hood open and saw SPARKS! Really scary.
Also, clean the ground point on the engine. May have a little rust preventing a good connection.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-01-2016, 05:24 PM   #8
hatzie
Moderator
hatzie's Avatar
Easy enough to do static voltage drop tests on both the ground and hot main power cables in the charging circuit with a decent Digital Volt Meter.
Set your meter on VDC
Measure from the - on the battery to bare metal on the block. If you read more than .2v you have a loose connection.
Measure from the + battery terminal to the Alternator BAT terminal. If you read more than .3v you have a loose connection.
Follow the wires and test at each available connection to the battery till the drop normalizes at or below .2v.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-01-2016, 06:40 PM   #9
wilkin250r
wilkin250r's Avatar
So you've already got one answer, but I'll give a little more detail. A 12V car battery is actually made up of 6 cells, each one just a hair over 2.1V per cell, giving you a full voltage of about 12.7V when fully charged. They'll actually hold a small overcharge, it's not uncommon to read as high as 13.5V fresh off a charger, but it will settle to 12.7 almost immediately when you put a load on, or after 24hrs sitting all by itself.
However, lead acid batteries like a higher voltage when charging, which is why your alternator is pushing 14.4V.
As to your other problem, it's very perplexing. When your engine does not start, are you getting literally "nothing"? No cranking at all, no solenoid noise, nothing?
I can think of several reasons you would measure 12.5V but not be able to start. But half of those reasons wouldn't disappear with a jump-start, and the other half wouldn't disappear the next day. NONE of those reasons would exhibit both of those symptoms, I'm totally confused, and would like more information.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 07-02-2016, 07:55 PM   #10
Nick_R_23
Nick_R_23's Avatar
Are you missing the heat shield on the starter solenoid? People are notorious for leaving those off when the original starter got changed many years ago. Likely you'll need a new one but also make sure the heat shield gets put back on as well. As everyone else has stated, check all the wires for looseness, bad connections, or bad crimp/solder joints.
