06-29-2016, 08:33 PM | #1 |
It can't possibly fit ! Steering Column issue
Hey gang, how in the world do I swap out the wire loom in the steering column in my 72 GMC with tilt, TH400, 402 extra long bed (it's not a longhorn, that would be Chevrolet, what do I call mine, other than extra long?).
Anyone with some steering column advice, I'd sure appreciate some ideas. Got it all apart, top of harness just hanging and can't get fitting up through to top. Thanks in advance for your ideas. This is probably on 50 other threads already and I can't see 'em cause my eyes are shot today. CousinTone Last edited by CousinTone; 06-29-2016 at 08:40 PM. |
06-30-2016, 06:39 AM | #2 |
Re: It can't possibly fit ! Steering Column issue
Pictures would help with showing what you are trying to do
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
06-30-2016, 08:52 AM | #3 |
You need to remove the wires from the hub and reattach them after you pull it through the column. Although I have read that some guys can get it through the column by loosening some pieces, but I never fought that battle.
I believe the GMC version of the longhorn is called a Custom Camper.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
06-30-2016, 06:07 PM | #4 |
I just switched out a turn signal ass. this morning. I make a good diagram of the wires and plug, then take some pics. Then pull the ends out of the plug and thread em down the columm and put the wires and plug back together. pretty simple that way.
06-30-2016, 10:21 PM | #5 |
Born Psycho
this is the easiest way i've found also.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
