A/C Dryer ??
![]() Join Date: Sep 2005
Re: A/C Dryer ??
Im goinv go go with the right side as the in side since it has in stamped on top there
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Re: A/C Dryer ??
Re: A/C Dryer ??
its right comes from the cooler and goes to firewall
Re: A/C Dryer ??
Flow is from the compressor to the condenser, through the drier, to the expansion valve/evaporator.
It looks like it's connected properly
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#6 | |
Re: A/C Dryer ??
My Next Question Does This 71 Truck Have And Orfice Filter In Line If So Where Is It ? Thanks Harley03joe ![]() ![]() ![]() |
Re: A/C Dryer ??
![]() Join Date: Mar 2003
Re: A/C Dryer ??
No orifice tube on the 71 if it is still factory. Factory is a POA system.
Re: A/C Dryer ??
If you are going with 134a, recalibrate your poa valve.
Re: A/C Dryer ??
Re: A/C Dryer ??
Re: A/C Dryer ??
I Just Got My New POA Valve 134 From Classic. After I Evacuate And Pump Down The System, Question Where Do I Hook Up The Wires The Instuction Are Not Real Clear. The Instructions >>>Replacement for the original POA Valve. Converts the POA System to a Cycling Clutch System like found on most Late Model Vehicles. Saves Gas Milage and decreases length of load on the engine. Easy to install and is compatable with R134 refrigerants. I Also Replaced The Dryer And What Should My Gages Read When Full >>> Low 130 >> Hight 230 ? Also Has And One Used The 134 New POA Valve ? Thank You For Any Help In This Matter Harley03joe ![]() ![]() ![]() ![]() |
#13 |
Re: A/C Dryer ??
I don't think many people are happy with the POA eliminator pictured. It turns your system into a cycling system that is normally used with a orifice tube.
Originally, and mostly likely still do, you have an expansion valve as the metering device. It's used with a continuously running compressor. The POA helped control the pressure in the evaporator core. More modern A/C systems might use an expansion valve without a POA. By adjusting the expansion valve you might be able to get decent performance without the POA. The switch above would then become a protection device edit to answer your questions. I do not believe you can buy a "new" POA The wire on the switch goes in series with the green wire going to your compressor Google a 134a pressure/temp chart. While running low side pressure should be 35-40 psi.
