Old 06-30-2016, 11:00 PM   #1
spookylynx
spookylynx's Avatar
to cross over?..... or not.
Well, it's almost time to route exhaust. The question is... Should I run a cross over pipe? or an H pipe? or nothing? I was just going to do simple glass packs and dump it down.
What is the advantage or a cross over pipe? I'm not running crazy HP, fairly stock 350 with some headman long tube headers.
Thoughts?
spookylynx is offline   Reply With Quote
Old 07-01-2016, 10:10 AM   #2
SS317
SS317's Avatar
Re: to cross over?..... or not.
I'm looking at doing this kit that has the crossover in it.
https://www.summitracing.com/parts/wlk-89027
I have glass packs with straight pipes now, very old and rusting, and it sounds really good at idle, but going down the road it's too loud for me.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 07-01-2016, 10:17 AM   #3
TJ's Chevy
TJ's Chevy's Avatar
I did true duals on my gmc 305 v6. I believe the only reason you really need any cross over...H pipe, X pipe, ect. Is for high rpm use. Supposed to help even out the flow or something to that nature.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 07-01-2016, 11:38 AM   #4
69chevytrucker
69chevytrucker's Avatar
im true dual as well
69chevytrucker is offline   Reply With Quote
Old 07-01-2016, 11:39 AM   #5
69chevytrucker
Old 07-01-2016, 01:02 PM   #6
BRASSHEAD
BRASSHEAD's Avatar
I think a cross over or an x-pipe will mellow the sound a bit also.
BRASSHEAD is offline   Reply With Quote
Old 07-01-2016, 01:16 PM   #7
gabbin
gabbin's Avatar
H pipe, it will equalize the exhaust pulse and retain lower end torque. you can run both straight it will work, but it is simple to put the H connection in.
gabbin is offline   Reply With Quote
Old 07-02-2016, 10:38 PM   #8
spookylynx
spookylynx's Avatar
I'm not using a kit, just going to make all my own pipe so I pretty much have free reign. Is it better to have a cross or H closer to the headers or a certain distance away? or does it not matter where.
Planned on simple glass packs and dump it straight down similar to 69chevytrucker posted above.
Old 07-02-2016, 11:49 PM   #9
Chknlyps2
This explains a little.
Chknlyps2 is offline   Reply With Quote
Old 07-04-2016, 01:41 PM   #10
spookylynx
spookylynx's Avatar
that was a good video.
thanks
