Old 07-01-2016, 09:14 AM   #1
jsera
Weatherstrip wont let doors close
Hey guys, I'm putting my 72 back together and replaced the weatherstrips with the channel/push on type rather than the glued type. Anyways, after installing the weatherstrips my doors wont close right, I have to slam the door with all my might to get it to close on the weatherstriping. Has anyone else had this issue? Any suggestions?
jsera is offline   Reply With Quote
Old 07-01-2016, 09:29 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Weatherstrip wont let doors close
Just about everyone that has put on the slip on weatherstrips has that problem. Especially if the door fits a little tight to begin with.
Try moving the striker plate out a bit. Be sure and mark around it with a fine felt tip marker first so you can tell how far you have moved it. Only go about 1/16" at a time and don't let it move up or down, just out.
LockDoc
Leon
Old 07-01-2016, 11:22 AM   #3
jsera
So you pretty much have to sacrifice your door lining up right?
Do they eventually wear in having the doors shut over a while?
Old 07-01-2016, 11:29 AM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Don't know if it's recommended, but I plan on baking mine in the sun some before install. If yours are clip-on, pull em and give that a try. Other than that, Doc knows these trucks very well. If you have the space and latch plate shims, add one top and bottom, see what happens.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-01-2016, 01:06 PM   #5
everettelane
everettelane's Avatar
I replaced mine a few weeks ago and talked to others that have had the same problem, they will eventually squash some and relieve so its not so hard to close but you need to adjust the door striker so the exterior of the door is flush with cab.
everettelane is offline   Reply With Quote
Old 07-01-2016, 01:26 PM   #6
davepl
davepl's Avatar
I always specify SoftSeal, with their motto being something like "stop SLAMMING that door", and they close perfectly. I think it definitely depends on the material being used to make the seal.
I've always been very happy with it on every restoration I've used it on so far! No slamming, no closing twice, no moving the door out...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-01-2016, 02:05 PM   #7
jsera
I got my seals from gmcpaul
my doors do close flush to the exterior already but I have to slam them with all my body weight behind it for them to latch properly
Old 07-01-2016, 05:35 PM   #8
Thundarr
Thundarr's Avatar
I replaced mine with newer clip-on style about 2 years ago and they are just now beginning to soften. Wish I would have known about the "soft seals".
I may still switch. I had to move my strike plate out so the doors never look completely closed.
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 07-01-2016, 10:09 PM   #9
71CHEVYSHORTBED402
Do they clip on?
Tony
