07-01-2016, 09:52 AM | #1 |
Chevy Front & Rear Axle Identification #s
Hello All,
I'm trying to figure out what the axles are in a 4x4 truck that I just picked up. I can read the front numbers pretty easy, the back is going to take some work. My question is there a site or place that I can go to plug the numbers in to figure out what I have? Thanks, Mark |
07-01-2016, 01:31 PM | #2 |
Re: Chevy Front & Rear Axle Identification #s
Does this help? http://ck5.com/forums/resources/axle...tion-chart.10/
It only has original paint once |
07-01-2016, 02:00 PM | #3 |
What year tk? 1/2t? 3/4t?
1961 chevy K10 my build is------------61K10 build |
07-01-2016, 02:47 PM | #4 |
After decoding the VIN it says it's a C10, but the axles are obliviously 4x4. There's not a lot to go on, as you can tell by looking at the pic.
07-01-2016, 03:18 PM | #5 |
need a pic of the axles and hubs. A pic of the front frame also. ft axle should be a dana44 or a gm 10bolt. rear should be a 12 bolt. sorry, need pics to help.
07-01-2016, 03:23 PM | #6 |
I'll get you pics tonight when I get home or tomorrow morning. I know the front has disc brakes on it, not sure if it was converted over or what. The rear is a 10 bolt, I do know that.
07-01-2016, 11:48 PM | #7 |
60-66 Nut
The frame and running gear are not original to the cab. It is a '73-'87 frame and running gear. If the rear is a 10 bolt it is likely a '80-'87. The front is likely a 10 bolt also. Do the covers look the same front and rear?
