Old 07-01-2016, 12:22 PM   #1
reed62
reed62's Avatar
Removal tool for door latch and window regulator
Hey all,
What special tool did you use to remove the square looking fasteners on the window regulator and door latch mechanism? Or did some of you just grind them off and replace it with traditional hardware?
reed62 is offline   Reply With Quote
Old 07-01-2016, 12:33 PM   #2
jtrichard
Re: Removal tool for door latch and window regulator
Are you talking about a screw that looks like the one in post #2 here? http://www.trifive.com/forums/showthread.php?t=47796 That is a clutch head the drivers are available
jtrichard is offline   Reply With Quote
Old 07-01-2016, 12:34 PM   #3
reed62
reed62's Avatar
Yep...that would be the one.
Old 07-01-2016, 12:44 PM   #4
jtrichard
Here is one on EBAY http://www.ebay.com/itm/CTA-8755-4-P...930842&vxp=mtr
Old 07-01-2016, 12:48 PM   #5
reed62
reed62's Avatar
Cool...thanks. I will look locally to see if I can round one up
Old 07-01-2016, 04:20 PM   #6
forestb
forestb's Avatar
I have used a big flat head screw driver or a pair of needle nose pliers just to get them out instead of buying a new tool. I replaced them with phillips head bolts.
forestb is offline   Reply With Quote
Old 07-01-2016, 11:57 PM   #7
Captainfab
60-66 Nut
Check your local Napa. I bought a clutch head screwdriver there once.
Old 07-02-2016, 12:27 AM   #8
Brad54
Brad54's Avatar
Snap-on sells them too... and while I know Snap-on is usually expensive, I still bought all the clutch-head sizes they have (it's three or four).
Holley carbs also use a small one, so I figured I'd get them all.
They also show up at swap meets and pawn shops once in a while, so I've also got a set of the bigger ones in my junkyard tool box, which has come in handy more than once.
No... I am NOT a tool junky... :-)
okay, maybe a little bit of one, because I also have a full set of clutch-head sockets for 3/8-inch ratchets that I've put together one-at-a-time from the swap meet. And was damn glad I had 'em when it came time to take the barn door hardware off a junkyard Suburban!
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 07-02-2016, 09:20 AM   #9
63burban
Chevy addict
Classic Truck Parts sells them
63burban is offline   Reply With Quote
