Old 07-01-2016, 05:01 PM   #1
hillshooter
Pie cut Upper control arm
Hello guys and gals.
Anyone have any pictures of how to pie cut the UCA? Iv found acouple threads on here but the pictures no longer come up. I need to cut on my s10 UCA to relieve abit of the binding. Thanks
hillshooter is offline   Reply With Quote
Old 07-01-2016, 05:45 PM   #2
Bushwickbill
Bushwickbill's Avatar
Re: Pie cut Upper control arm
Well someone els probably has better illustration but the s10 control arms can be tricky to do because the way there shaped.
the Red area is of course the pie cut, the Blue line is where i bend it ( i sometimes score the blue line with a cut off wheel to allow it to bend easier)
The yellow section is where its tricky. i have just pie cut it all the way across and then weld it back up. or you could remove that section completely then add in a new flat plate when the control arm is bent
For off-road use only haha
Bushwickbill is offline   Reply With Quote
Old 07-01-2016, 06:33 PM   #3
joedoh
joedoh's Avatar
nice picture kylie. its 20% as big as the background. everyone welcome kyle.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 07-02-2016, 05:46 AM   #4
hillshooter
Thanks for the picture, gives me a better idea of what im dealing with. Is there any kind of measurements?
Old 07-02-2016, 10:56 AM   #5
MARTINSR
MARTINSR's Avatar
I am fascinated by how much work has to go into these frame "swaps," just modify the stock frame and suspension it's much easier!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 07-02-2016, 11:20 AM   #6
joedoh
joedoh's Avatar
Brian
well, this has nothing to do with swapping frames. this is about bagging it on big wheels and not buying tubular arms to correct the balljoint angles. you cant bag a stock suspension very successfully, unless you raise the motor or clearance the oil pan.
so fair warning, in the future when someone asks how to clearance the oil pan to bag a stock frame and suspension, I will probably post something like "I am fascinated by how much work has to go into keeping the stock frame and suspension, just install an IFS or s10 swap its much easier!"
the easy way to pie cut is to leave it all together, pie cut it like kyle shows above, and lay the truck out. the weight of the truck will pull the pie cut together, you can weld it all up at that point. or just buy some tubular control arms, because its just as likely that the upper arm/balljoint isnt binding but the lower arm is bottoming out on the frame. tube arms fix all of this, that goes for a mustangII, camaro swap, G-body swap, and s10 swap.
Old 07-02-2016, 11:22 AM   #7
hillshooter
[QUOTE=MARTINSR;7641555]I am fascinated by how much work has to go into these frame "swaps," just modify the stock frame and suspension it's much easier!
Brian[ This is on the stock frame with a Danforth IFS.
Old 07-02-2016, 11:42 AM   #8
joedoh
joedoh's Avatar
coach in the project threads has installed a danforth, I dont remember if he pie cut his uppers but its worth a read.
http://67-72chevytrucks.com/vboard/s...d.php?t=554051
edit: he did! starting about the middle of this page
http://67-72chevytrucks.com/vboard/s...554051&page=38
Old 07-02-2016, 04:02 PM   #9
MARTINSR
MARTINSR's Avatar
[quote=hillshooter;7641577]
Ahhhhh
You can see my distaste for the frame swaps slither through. Thanks for putting up with me.
Brian
1948 Chevy pickup
Old 07-02-2016, 04:03 PM   #10
MARTINSR
MARTINSR's Avatar
I got off the fashion train quite a while ago.
Brian
1948 Chevy pickup
Old 07-05-2016, 11:22 AM   #11
Coach529
Coach529's Avatar
Super easy.
I had my truck chassis on jack stands and used a 4-1/2" skinny wheel to make the cuts. Then lay the truck out. I ended up raising it up again and removing some more material.
Once layed out and enough material has been removed......tack them good. The pull them off and final weld.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 07-05-2016, 11:38 AM   #12
Coach529
Coach529's Avatar
1949 Chevy 3600
Old 07-05-2016, 11:29 PM   #13
neverfinished52
neverfinished52's Avatar
Not sure if you know but Michigan Metal Works sells s10 uppers for $150. I'd personally be too worried about cutting my control arms
http://michiganmetalworks.com/store/...&product_id=71
neverfinished52 is offline   Reply With Quote
Old 07-06-2016, 09:53 AM   #14
Coach529
Coach529's Avatar
Michigan Metal Works stuff is pretty much junk. A quick Google search shows that there quality and engineering is suspect!!
1949 Chevy 3600
Old 07-06-2016, 10:30 AM   #15
neverfinished52
Wow, I thought their stuff was good. Thanks for letting me know. Good luck with your project
Old 07-06-2016, 12:02 PM   #16
lolife99
67-72 parts collector,…
lolife99's Avatar
Really?
I did a quick Google search and only found two threads.
I've never had any of the MMW a-arms,... But I've seen quite a few trucks built with them.
They make a-arms and custom spindles from many vehicles that no one else bothered to address.
What were the exact problems?
Keith
Convert to disc brakes.
Old 07-06-2016, 12:20 PM   #17
Coach529
Coach529's Avatar
Really?
Poor welds, poor (or no) engineering.
There is a reason they are the only company out there build control arms out of flat plate.
1949 Chevy 3600
Old 07-07-2016, 12:56 PM   #18
hillshooter
Thanks for the info Coach. I also tagged ya over on my FB 150 build page. What transmission drop do you have on your crossmember?
Old 07-07-2016, 01:22 PM   #19
HUSSEY
HUSSEY's Avatar
I always thought the flat plate looked goofy for control arms. You need to be grooving and stacking up your welds or welding really hot to get the necessary penetration on that thick of plate.
I was considering them in the future because they're the only one that make stretched control arms specific for an AD on an S10 chassis. However, I don't want to be putting my life in the hands of someone who doesn't FEA and follow engineered weld procedures and QA/QC for a product like this.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 07-07-2016, 02:24 PM   #20
lolife99
lolife99's Avatar
Michigan Metal Works also builds tubular a-arms.
Keith
