Old 07-01-2016, 10:07 PM   #1
dme922
dme922's Avatar
Need a longer dbw harness
Im running a 5.3 truck motor and due to where i am mounting my ecm my dbw harness is to short. Any suggesting on who makes an extension or longer harnesses?
dme922 is offline   Reply With Quote
Old 07-01-2016, 10:16 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Need a longer dbw harness
When I bought my psi harness the dealer told me I could get it made in custom length if needed..my next one will be custom length due to me mounting ecm under or behind the seat as well as maf sensor pigtail being a little longer,,
Old 07-01-2016, 10:18 PM   #3
dme922
dme922's Avatar
Thanks for the help
Old 07-03-2016, 08:21 AM   #4
Badger69
Badger69's Avatar
I just bought the correct color wiring and extended it myself. Soldered and heat shrank each slice. Took about 20 minutes.
'69 C10 | LS2 | 4L70e | 4 Wheel Disc Brakes | Accuair eLevel | 20" steel wheels | Porterbuilt goodies | Push Button Start | Tilt | Cruise
'79 Burbo | 2wd | 8100 Vortec/Allison swap | A/C | soon to be bagged.
Badger69 is offline   Reply With Quote
Old 07-04-2016, 04:24 PM   #5
Willie Makeit
Willie Makeit's Avatar
$40 worth of junkyard harness, soldering iron, solder and heat shrink will fix it. its just wires, not magic.
Willie Makeit is offline   Reply With Quote
Old 07-04-2016, 09:54 PM   #6
dme922
dme922's Avatar
I got in touch with John at Modern Vintage System and he is making me one thats 7 foot long at a very good price.
Old 07-05-2016, 12:47 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
IMO on DBW components I prefer re-pinning the harness instead of extending it. The DBW wires can be soldered, but it needs to be done VERY sparsely. Those circuits are a mix of 1.5v and resistance signals, both of which are fairly sensitive to incremental changes. Overheating of the wire, or over use of the solder or flux can create a hot-point and change the resistance across the wire. Not something to be done unless your very confident with the solder, and preferably have fine electronics soldering experience.
This can cause error codes if it creates values outside its range, or provide skewed signals which IMO can be frustrating and sometimes dangerous for both the engines health and driver control.
Most of those WeatherPak connectors can be disassembled with a thin flathead, and each wire de-pinned from the connector. The pins can be ordered in bulk if they cannot be reused. Then the custom length wires can be measured and cut, pinned into the connector and installed. Its a pain, but its a really nice way to get your own "custom" harness, it requires less talent then solder, and looks soooo nice when done.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-05-2016, 10:50 AM   #8
Custom 68
Custom 68's Avatar
Thats interesting Brew, I am working on a gen 5 harness and was making my DBW stuff and just going at it. It will give me something to look at if I do throw some errors. I had added some wire and a disconnect trying to make a nice clean setup maybe the thing to do but know I know what to look for if it gives me fits.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-05-2016, 11:18 PM   #9
65Gregg
65Gregg's Avatar
Where did you find the wire that matches the various colors found in the GM harness?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 07-05-2016, 11:25 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Trailer supply places, any automotive wiring retailer online, and some good electronics or electricians supply house (just be wary that your not buying construction wiring, which isn't vibration resistant).
Old 07-06-2016, 05:28 AM   #11
Wgesnerjr
Wgesnerjr's Avatar
Not sure if this will work for you or not.
http://www.ebay.com/itm/181718006939...%3AMEBIDX%3AIT
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 07-07-2016, 01:49 PM   #12
Hart_Rod
Hart_Rod's Avatar
Hart_Rod is offline   Reply With Quote
Old 07-07-2016, 10:53 PM   #13
65Gregg
65Gregg's Avatar
I guess I wasn't clear, I've never seen wire available that follows the color schemes (2 color combinations) found in the factory LS harness. I would want to stay with the correct colors for any future trouble shooting.
I assumed Badger had found a source.
65Gregg
Blue long bed
White TBSS
61 Impala
Old 07-17-2016, 10:47 PM   #14
Badger69
Badger69's Avatar
I found a guy at a swap meet that had rolls of gm-type wire.
