Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-03-2016, 07:56 AM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Track / Panhard Bar FS
This is a new unused Trac Bar (track bar) or Panhard bar. Long Style that mounts from the passenger side trailing arm to the drivers side frame. I opened the box for the pics.
I'd rather you drop by and pick it up if your in the Waco, TX area -$100
From Early Classic - called the Super Track Bar Kit (they sell it for $129 plus shipping):
http://www.earlyclassic.com/catalog....gory=Drop+Kits
"When lowering the rear of a C-10 Truck, certain geometric changes occur that need to be corrected. For the rear suspension to perform properly, we pioneered the use of an Adjustable Panhard Bar on our Project ’72, as well as relocated rear shock mounts to correct mis-aligned geometry.
With a rear drop of more than 5”, the stock panhard bar actually runs at an uphill angle to attach to the rear axle. This causes the rear end to shift to the driver’s side as the rear suspension travels downward, creating an ill-handling driving situation.
Our Original Super Track Bar Kit eliminates this problem by moving the mount from the rear axle housing over to the right side trailing arm, which lowers the bar’s mounting point and corrects the angle. It’s extended length lessens the side to side radial arc, and the adjustable end allows the rear axle to be centered between the frame rails.
Installation is a simple bolt-on arrangement, with no welding required. We use only the highest quality, NASCAR-grade D.O.M. (drawn over mandrel) seamless tubing to build all of our bars, for maximum strength and integrity. Every Early Classic Panhard Bar and Super Track Bar feature heli-arc welds, C.N.C. machined threaded spud inserts and a powder-coated finish. Each kit comes complete with all necessary hardware and instructions. "
Old 07-11-2016, 05:41 AM   #2
The Rocknrod
Moderator
Re: Track / Panhard Bar FS
Bump
