Old 07-03-2016, 06:05 PM   #1
RodnRudy
RodnRudy's Avatar
Windshield sealer
What are you guys using to seal the windshield rubber on the outside in the upper and lower corners. I bought some 3M glazing and bedding compound. It is non hardening so the rubber can be removed later if needed. Am I on the right track or should I use seam sealer?
RodnRudy is offline   Reply With Quote
