Old 07-03-2016, 06:49 PM   #1
wildfifty2
52 Chevy axle drop (where do these go)
Justed received my dropped axle and modified steering parts back From Nostagia sids. Have everything mostly back together but it has been several weeks since pulled it apart and i do not recall where i pulled these thick flat washers from. There are two left over per side. I am guessing they came from behind the brake backing plate near the large spacers but would love it if some one knew for sure.. Thanks
wildfifty2 is offline   Reply With Quote
Old 07-03-2016, 08:58 PM   #2
nvrdone
Re: 52 Chevy axle drop (where do these go)
have you installed the spindles yet? if I remember correctly, there is a bearing tat looks like a thick washer that goes between the lower spindle and the lower side of the axle.
I don't remember a spacer that goes over the spindle shaft inside of the backing plate.
nvrdone is offline   Reply With Quote
Old 07-03-2016, 09:04 PM   #3
wildfifty2
Thanks ... I shipped the axle off with the spindles attached and Sid replaced the king pins and shipped it back with the spindles attached. I am still guessing that they are off of the bolts that go through the backing plate as well as the steering control arms.. I am just not sure where?
Old 07-03-2016, 09:27 PM   #4
mr48chev
mr48chev's Avatar
If they are needed between the backing plate and the spindle you would see the gap between the backing plate and spindle on the other holes when you tighten the bolts in the holes with the thicker spacers.
My ongoing truck projects:
Old 07-04-2016, 12:18 AM   #5
ADchevys
There is washers that go in between the axle and shock mounts.
ADchevys is offline   Reply With Quote
Old 07-04-2016, 12:27 AM   #6
wildfifty2
Hmm.. that is interesting.. I know I did not put any there... I will check that out.. Thanks
