Old 07-03-2016, 09:54 PM   #1
reb162
reb162's Avatar
B-Pillar and Outer Floor Extension Patch Panel Question
Beginning my cab repair and I pulled my rockers today to see what was underneath so I know what patch panels I need to order. I need typical stuff...a-pillar patch, lower kick panel patch and the outer floor extension patch to fix the other edge of the floor and the rocker closeout that is rusted out in places.
My problem is that my can corners and the b-pillars are actually in great shape, but the cab floor is slightly rotted about and inch or two aft of the b-pillar. So when I install the outer floor extension, it will have to go past the b-pillar, but I do not see a way of doing that without cutting out the b-pillar and maybe the corner?
Any advice?
My current thought is to try and cut the b-pillar only a couple inches up and try to leave the cab corner in place and that might give me enough room to get at and cut the outer floor past the corrosion. Pics below.
1971 Chevy C-10
Currently is rust repair
reb162 is offline   Reply With Quote
Old 07-04-2016, 10:56 AM   #2
Nsanehotrodz
Nsanehotrodz's Avatar
Re: B-Pillar and Outer Floor Extension Patch Panel Question
I bet if you cleaned up around the bottom of the cab corner it will have a few holes show up. I would go ahead and cut the cab corner out and the b-pillar. If you use a small blade on a air saw you can clean the b-pillar and re-use it if its good.
www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
