Old 07-04-2016, 12:03 PM   #1
Alexreed67
67 c10 lift
Hi I am new to this forum and I just bought a 67 c10 and its needs new suspension but I want to lift it a bit to stock height or a little higher so I can get 33s on it. Should I try to get suspension from a c20 or c30?
Alexreed67 is offline   Reply With Quote
Old 07-07-2016, 01:52 AM   #2
andrewmp6
Re: 67 c10 lift
You can run 1 ton springs those will get you maybe inch and half over stock height.Higher then that you can use 88-98 lift spindles but you have to replace your ball joints tie rod ends and use the brakes from the 88-98.Is your rear coil springs or leaf springs?
andrewmp6 is offline   Reply With Quote
Old 07-07-2016, 02:03 AM   #3
Alexreed67
Re: 67 c10 lift
The rear uses coils pig tail on both ends I want to get the truck this height
