Old 07-04-2016, 12:41 PM   #1
PE 017
steering box
Hey guys, working on a 50 chev 1/2 ton pick up. Is there any adjustment on a stock steering box for play side to side, like newer manual boxes. also i am assuming it uses 90 wt. gear lube? how to drain and amount to refill? thanks.
PE 017 is offline   Reply With Quote
Old 07-04-2016, 12:58 PM   #2
solidaxel
solidaxel's Avatar
Re: steering box
Is it the box or tie rod ends?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-05-2016, 12:40 AM   #3
PE 017
Re: steering box
well i pulled it down off shelf, have not looked at it for about a year. It does have a lash adjustment just like most of them, duh. Maybe take out the lowest bolt toward the bottom to drain, then add oil in top plug up to top bolt on side?
