10-02-2003, 02:15 PM | #1 |
Will 6 lug disc brakes of 73-87 4 x 4 work on 69 conversion
Can I use the rotors off a 4 x 4 front end to go on a 2 wheel drive crossmember from a 73 - 87 truck to maintain the 6 lugs?
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
10-02-2003, 08:06 PM | #2 |
Not Dusti,just Bob
I would not think so.4x4 uses totaly different suspention on the front than the 2-wheel drive,4x4 use leaf springs on the front and the 2 wheel drive uses coil springs and a-arms,I'am sure something just would not fit correct,maybe some body with more experiance has more info on it.
Bob W
72 cheyenne super 1/2ton 89 camaro |
10-02-2003, 10:17 PM | #3 |
i wouldnt see why the rotors wouldnt work, since thats what you were asking. not sure if they go on the same way or not. never had my 87 apart
S-C |
10-03-2003, 09:52 PM | #4 |
Not Dusti,just Bob
Rotors
I looked in my chevrolet pickup parts interchange manual 1967-1978.
There were no interchanges for 4x4 to 4x2. I would think that the center of the rotor would be larger on a 4x4 for the locking hubs? I have read a few post about people wanting to keep 6-lug and have disc brakes but don't recall anybody having that sugestion. Plus that would be way too easy if you could just swap a few parts and keep 6-lug and get disc rotors Try it and let us know,I would like to put disc brakes on my wifes truck and be able to keep the wheels that are on it without buying a kit for big$$.
10-03-2003, 11:43 PM | #5 |
its all about the +6 inches
The 2 wheel drive has the bearings and races in the rotor while every 4X4 I have ever worked on (which, admitedly is a very small number) had a 'hat' style rotor that slid over the hub assembly.
10-04-2003, 09:05 AM | #6 |
conversion
4x4 will not fit 2wd. spindles rotors are completly different. sorry to be the bearer of bad news
70 GMC SHORT STEP , 71 BLAZER ,72 JIMMY,72 BLAZER, JUST NEED THAT SUBURBAN NOW......WANTING MORE |
