Old 07-04-2016, 10:44 PM   #1
lowbuck
disk brake question 5 stud to 6 stud
I have a 1985 C-10 complete front end that I am going to be swapping into my 1965 C-10 it has the 1-1/4 wide rotors that are five stud. Is there an OEM six stud rotor that will bolt onto the spindle and line up with the caliper so that my front and rear bolt pattern will be the same?
lowbuck is offline   Reply With Quote
Old 07-04-2016, 11:43 PM   #2
LVPhotos
LVPhotos's Avatar
Re: disk brake question 5 stud to 6 stud
http://www.classicperform.com/Store/...062SWBK5OE.htm
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-05-2016, 11:22 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
There is no factory GM rotor for this application that is 6 lug. All 2WD trucks from '71-'87 were 5 lug. That said, almost all of the truck vendors sell 6 lug rotors that would be for the disc brake conversions. They are not something you can walk into a parts store and buy, you have to order them from a vendor. My recommendation is Early Classic Enterprise as they use Raybesto rotors.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-05-2016, 01:45 PM   #4
lowbuck
Thanks for the info, I was hoping that the newer six stud chev rotor's would work.
Old 07-05-2016, 02:13 PM   #5
chevy_mike
chevy_mike's Avatar
It can be done but you have to use '93-'98 spindles, '73-'87 3/4 ton lower arms, tie rod adapter sleeves and matching ball joints for the spindle. Then you can use either the 5 or 6 lug rotors for '93-'98.
Much simpler to use the aftermarket 6 lug rotors.
Old 07-05-2016, 02:59 PM   #6
verdell
verdell's Avatar
Try 1988 C2500 3/4 ton 2wd rotors.
verdell is offline   Reply With Quote
Old 07-05-2016, 03:16 PM   #7
chevy_mike
chevy_mike's Avatar
They will not work with pre '88 spindles.
Old 07-05-2016, 08:40 PM   #8
verdell
verdell's Avatar
I just went out to my shop and dropped the old 88 C2500 6 lug rotors onto a '75 1/2 ton spindle with bearings and spindle nut...it does work...
Old 07-05-2016, 09:08 PM   #9
lowbuck
Verdell are the 88 C-2500 rotors the same width and diameter as the 1985 five stud rotors?
Old 07-05-2016, 09:52 PM   #10
verdell
verdell's Avatar
The 6 lug rotors are "light duty" 3/4 ton application. The rotor thickness is the same as 1/2 ton "heavy duty" 5 lug rotors but I think the overall diameter is slightly different. I used to run the 6 lug rotors on my truck and switched to 5 lug. Everything bolted up with no issues. Hope this helps
Old 07-05-2016, 10:24 PM   #11
lowbuck
The 1/2 ton five lugs that I have are 1-1/4 thick and 12" across through the center. Are your 3/4 ton light duty the same specs?
Old 07-06-2016, 12:10 AM   #12
Captainfab
60-66 Nut
Yes they will fit the spindles as the bearings are the same. But did you try and install a caliper and pads? It won't line up.
I've been over this years ago. And using the '88-'98 spindles apparently won't allow enough camber adjustment.
Old 07-06-2016, 12:20 AM   #13
lowbuck
Thanks Captainfab, so it looks like there is no fix using OEM parts. I have been looking for your post on what stock axles fit the diff that are five stud.May be an easier fix.
Old 07-06-2016, 11:57 AM   #14
Chevy Fleetside
Chevy Fleetside's Avatar
https://www.summitracing.com/parts/clp-cp4r-6 Copy and Paste is nice...
Classic Performance now offers upgraded brake rotors in standard or drilled-and-slotted styles for their disc brake conversions. These are the same high-quality pieces found in Classic's complete brake kits. All components work with their drop spindles or stock 1971-72 and 1973-87 stock spindles. Classic Performance upgraded disc brake conversion rotors are made with premier materials and craftsmanship to ensure a great fit and dependable performance.
Here is a Review.
The right rotor for front disc conversion!!!
Summit RacingSummit Racing Verified Purchase
CLP-CP4R-6
I used 85 chevy truck stock spindles for my disc brake conversion of my 69 gmc truck and wanted to keep the old school wheels! This saved me time and money, they fit like a glove, perfect fit!
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is online now   Reply With Quote
Old 07-06-2016, 10:57 PM   #15
lowbuck
Thanks Chevy Fleetside, I am also trying to keep my steel (disk brake) wheels with hub caps.I have belltech dropped spindles with the 1985 C-10 front end installed. If they will fit that is the way I will probably go.
Old 07-07-2016, 12:30 AM   #16
Captainfab
60-66 Nut
There aren't any OEM axles that will work in the '63 to early '70 12 bolts and give you the 5 x 5 wheel stud pattern. The '71-'82 12 bolt axles are .750" too long. You will need aftermarket conversion axles or have your axles plugged and redrilled. But before you do that make sure the wheel bearing surface is in excellent condition.
Old 07-13-2016, 06:19 PM   #17
Rockit
Rockit's Avatar
Here is what I did to my 66' I found a 1/2 ton 1984 truck moved the hole front over to my truck, then I moved brackets from my truck axle to the 84 axle and installed in back In to my truck. So now I have 5 lug front and back for $100.00. I did install drop spindle, 4" drop springs front and back. New adjustable track bar. The new axle Is a 11/2" wider on the 1984, so It pushed the wheels out a little bit and they fit great. Also I think the new gears are 308 or something close to that not 4.11 it had
Rockit is offline   Reply With Quote
Old 07-14-2016, 01:08 AM   #18
lowbuck
Thanks I have an 1985 parts truck so I am thinking of doing the same. Thef parts will all match along with the wheels.
Old 07-15-2016, 01:35 AM   #19
64shortbox
64shortbox's Avatar
I did the exactly as Chevy Fleetside said. CPP drop spindles & rotors from Summit (the best price I could find) and the 6 lug rotors work out to be less than $25 per rotor more than the stock 5 lug rotors from Auto Zone. When I bought my truck it already had 15" X 10" rims on it and I didn't want to buy all new rims. I'm also extremely CHEAP and even used ALL the 73 brake lines & proportioning valve from the 73 Donor Truck but I did have to fab up a bracket to mount the proportioning valve in the correct location. The brake lines & proportioning valve all look factory because they are.
64shortbox is offline   Reply With Quote
