07-05-2016, 09:10 AM | #1 |
Vent window installation question
Just received my new vent windows and was wondering if I install them in my bare doors (no windows/handles/locks or mechanisms), will that cause a problem when I install the other stuff? Said another way, is their preferred order of installation of all of the door parts? Thanks in advance.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-05-2016, 09:26 AM | #2 |
Re: Vent window installation question
Install them . Just don't install the side window or door channel felts .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-05-2016, 09:37 AM | #3 |
67-72 parts collector,…
I usually have everthing in the door including the door glass (off the track) resting in the bottom of the door.
The completed vent window assembly I install last. Then move side window back into its track. I'm following this thread to learn if I have been doing it wrong all these years. Ha.
07-05-2016, 12:24 PM | #4 |
I have alway kept the vent wondows out till the door glass is inside the door. Make sure you dont install the scrapes and fuzzies till last
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 07-05-2016 at 12:32 PM. |
07-05-2016, 12:29 PM | #5 |
The Older Generation
I posted how I do it in this thread.... http://67-72chevytrucks.com/vboard/s...d.php?t=660294 You pretty much need to scan through the whole thread. LockDoc
07-05-2016, 01:02 PM | #6 | ||
"I ain't nobody, dork."
Subscribed, as I have to do the same thing soon.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-05-2016, 02:13 PM | #7 |
Here are the disassembly steps, which I based on the shop manual, and which I followed. Reversing them should give you assembly steps!
Remove outside mirrors Remove driver's door panel Remove window regulators and lock hangles Remove vent windows Remove main glass from doors Remove regulators from doors Unclip 2 rods from each door latch Remove latch Remove pull knob from lock rod Remove handle rod and armature Remove door handle Remove chrome strip from inside of door Remove Custom Camper emblems from doors Remove cowl to cab seals Remove door with hinges still attached to doors Remove door strikers - count shims
