![]() Join Date: Mar 2012
slip yoke questions 69 gmc 4x4
i have a 69 gmc 4x4 3/4ton and just installed a 4" spring lift. front stock slip is 7" and the rear slip (to center bearing) is 6". what new lengths do i need? and when done should both shafts be balanced? this has the rockwell 221. paul
Re: slip yoke questions 69 gmc 4x4
Are you saying your driveshafts are to short after the lift ?
no sir, they make the hookup but the splines are not even halfway in the slip joint, and the front wont let me thread on the grease cap. all i see offered are maybe 8'' long. i dont know if the longer ones will be enough. im trying to get an answer from a local place www.dennysdriveshaft.com
Dennys is good he will take care of you.
