1966 C10 Drumbrake Spindle damage
Hello Guyes,
i restore my 1966 Chevy c10 and put my Spindle out of the Rotor and see some scratches on the Spindle Shaft. Now i am a little bit afraid because i dont wand to take this Spindles back if it could maybe break. I am searching for some new Spindles, but i only found some for Disc Brake Set up. I need some Spindles for the Drum Brake Set up. I think about to change with disc brake in the front, but then i need a set of new Wheels, because the Calipers dont fit with the old 6 Lug Wheels of my Truck. Its to expensive for me now. I the Future maybe in 2-3 Years its ok. What do you think about my Spidles ? Where can a buy some new Spindles for my Drum Brake Set up with the old backplate ? Thank you all verry much. Greetings from Germany Nils ![]() |
Re: 1966 C10 Drumbrake Spindle damage
Here are more Pictures
More
More Pictures
More More More
Maybe the danage is not to bad on the Spindle ????
It's Better With Nitro
The areas that the inner bearing races contact look fine.
Never Ending Projects
You should be fine. That's not too bad and the areas where the bearing races go look to be in good shape.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
It looks like the threaded section was welded to the rest of the spindle. I wouldn't be concerned with the scratches on the taper, they look like tooling marks from it being machined on a lathe and the tool chattering. What looks like a weld is a little concerning though. If it has been welded, you never know how long it will last since that piece is heat treated and weld doesn't stick that well.
#10 | |
Thank you all verry much for your answers. |
Well if you wanted to be sure you could sand down the roughed up areas with emery cloth finishing up with about 400 grit, check for cracks with a 10X magnifier or if you want to throw some money at them have them magna-fluxed followed by shot peening. For shot peening you would want to protect the machined finishes with a rubber tape.
Much easier to find a spare set. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I agree that the spindle looks fine. You might smooth it up a little with some fine sandpaper, but I think it will be fine.
#13 |
60-66 Nut
That's not quite so easy in Germany.
#14 |
