Old 07-07-2016, 12:06 PM   #1
Figuarus
Figuarus's Avatar
Rear bags only - mounting solutions
hey guys. I've been trying to figure out the best way of mounting some airbags to my truck, but i'm not really finding what I need. I might be overthinking it, so I figure i'd run it by you guys.
My brother gave me a set of bags for the rear of my truck. For now, all I want to be able to do is adjust rear height.
This is the bag in question. I think these may be from a Topkick or something.
As you can see, i'm dealing with a 6" diameter plate, and about a 9" bag.
I called Pro Performance out of AZ regarding this kit:
http://www.azproperformance.com/60-7...ts-231156.html
Apparently my bags are too big for their brackets.
I was thinking about using aluminum billet and machining the holes I need to mount everything, but it's pretty expensive.
Does anyone have an idea of who makes a bracket kit that may fit this? Any other ideas I might have overlooked? I'm thinking about using wood at this point...(not really...just making a point )
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 07-07-2016, 01:29 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Rear bags only - mounting solutions
For an air spring that large, you may indeed have to fabricate your own upper/frame mount to ensure that the air fittings and mounting hardware fit and locate properly. You can use the smaller mount as a template. I would also double check clearances around the flutes. I run what is usually a front air spring at the rear and there were a couple of areas that had potential interference - I run a pro street size tire, so I had to be careful of wheel backspacing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-07-2016, 03:41 PM   #3
patrickk1
If that bag is from a topkick. Your ride is going to suck unless you carry 3000lbs in the bed.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
Old 07-07-2016, 04:07 PM   #4
SS317
SS317's Avatar
I have rear bags only and bought brackets and bags from AZ Properformance. They mounted right up. I don't have any picts, sorry, but they are working fine so far.
1966 Chevy C-10
350 Engine
700R4
SS317 is offline   Reply With Quote
Old 07-08-2016, 11:15 AM   #5
Figuarus
Figuarus's Avatar
yeah, I figured i'd have to make something work. I was hoping someone had used a bag similar to what I have and that maybe there was a bracket kit to fit a bag of these dimensions.
well, time to save up my pennies for material.
thanks guys
2013 Malibu LTZ
Old 07-08-2016, 11:56 AM   #6
vin63
vin63's Avatar
thanks guys
Before you make any purchases, double check the dimensions of the air spring to the available space around the frame and trailing arm mounts. It may be too large in diameter - my air spring is 6" in diameter (the widest parts of the flute) and it is close to my tire/wheel.
Old 07-08-2016, 08:47 PM   #7
Grandpa54
Grandpa54's Avatar
This is what i did, they work great, YOU CAN GET THEM AT EC IN FRESNO
Grandpa54 is offline   Reply With Quote
