![]() Join Date: Aug 2015
Help ID K10 Steering Gear - 67 or later?
I have a 67 K10 with power steering, and I want to replace the steering gear. Although my VIN and cab are 67, I am not sure about the rest of the truck.
Someone in another thread mentioned that the 67 K10 did NOT have a dimple in the frame near the steering gear. Can someone help me ID the steering gear/frame from the picture below? If it is not a 67 gear all the better, as I do not see anyone listing refurbished units for that year. Plenty available for 68-72 though. Thanks for the help. -Steve |
![]() Join Date: May 2003
Re: Help ID K10 Steering Gear - 67 or later?
I don't have a definitive answer for you, but your frame looks to be a 69 or newer. The radiator mounting bracket / spring mount are different on the 67-68 frames. If you look on top of the frame rail near the steering box there should be a number stamped into the frame. This is the vin # and if original to the truck it would match or partially match the vin of the body.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
This might help you determine what year your frame is, I also put a link to it if you can't read it.
http://www.lmctruck.com/icatalog/cb/t.aspx?Page=8
All about them K’s
![]() Join Date: Jun 2014
67 4x4 didn't have that style steering gear. It had ram assist. That doesn't look like a 67 frame to me. I've been wrong in the past tho.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#5 | |
It has an open knuckle front axle with drum brakes, which makes sense now. This is a huge help when servicing the chassis items. VIN/cab is 67, chassis is 70, 327 is 66. All my wife can think of is the Johnny Cash classic, "One Piece at a Time" -Steve |
#6 | |
I am glad I have the newer version, and have already ordered a replacement. For reference, my frame number is 0Z161077. I read that as 1970 made at the Fremont plant. -Steve |
Hopefully someone with that VIN doesn't want his frame back.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Hey Steve,
Here in NH, as long as none of the part numbers /vin numbers show up as stolen you can get a new vin for an assembled vehicle. It would need to be inspected' and all numbers found recorded by a state trooper or possibly by a reg car dealer. Or if it was already reg or titled all that's needed is a bill of sale for a vehicle that old. Gary
#9 | |
While I wait for the rebuilt steering gear to be delivered, I adjusted the one I have to see if I could take some play out. It helped a little, but I will be glad to get the replacement installed. -Steve |
