Alt, Bracket
I am looking for the part number of a Alternator bracket that mounts to the drivers side cylinder head, any help?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
![]() Join Date: Feb 2004
Re: Alt, Bracket
Worthless info --tried to delete my reply
If you are talking about the a v8 cast steel/iron alternator mount that is located driver side lower 2 bolt holes and one mount hole in side of block. I have one that has a casting number of 3857466 It could be 3867466 but the numeral does not look like the other 6's.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
