Old 07-08-2016, 05:25 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Son of a gun, my windshield washer works
I've owned this truck since 89 and the windshield washer wasn't set up when I got it. So I put some fluid into a bowl......nothing. Then I figured it needs to be pressurized and put the fluid into a correct jug.........trickle. Then I replaced the fluid with straight white vinegar and PRESTO.
I wanted to see if it worked before I remove it. Will run some fluid into it and call it good.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-08-2016, 05:34 PM   #2
projectking
projectking's Avatar
Re: Son of a gun, my windshield washer works
That's good to know , thanks for the tip!
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 07-08-2016, 05:40 PM   #3
71CHEVYSHORTBED402
Kind of a lazy way of doing things I guess, but it worked. Comes out like it was new. I made up for a good 7 years of use though. I must have pushed the button 50 times.
Tony
Old 07-08-2016, 05:54 PM   #4
tommys72
tommys72's Avatar
Hmmm...mine doesnt spray with the button either. The wipers come on, but no fluid
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 07-08-2016, 07:00 PM   #5
71CHEVYSHORTBED402
Try it out. Mine isn't leaking either, as of now anyway. Just be sure to pump it clean afterwards. I ran through near a full jug of fluid rather quickly, but I recommend distilled water instead. Then pump fluid through....Something I won't do until...tic...tic....tic...tic......2018? If seasoned I'd be done 2017, due to the alarm clock lacking relevance effective 5:00 pm-ish, on Dec. 30.
BTW, I didn't dilute the vinegar because I nearly gave up on the pump. Might not be a bad idea, but again, I'd use distilled water.
Tony
Old 07-08-2016, 07:04 PM   #6
tommys72
tommys72's Avatar
ill give it a shot and post up the results
Old 07-08-2016, 07:42 PM   #7
71CHEVYSHORTBED402
I should have mentioned I blew into the intake a few times. I also plugged the outtake here and there as needed. Both seemed to help. Just recounting common sense.........So fun and so CDO.
Tony
