Old 07-08-2016, 08:20 PM   #1
giftshopduane
Yet another tire rim question..
I picked up a set of 16x6 steel rims today and wanted to ask everyones opinion on best tire size for the narrow rim. I am looking for a clean combination of tall and thick (not wide). I am mixed on the look of tall and narrow on a 4x4 suburban, I'd like to fill out the wheel wells a little bit without it looking silly.
I am thinking 255/85 16 or 33/10.5 16 unless you think its too wide for a 6" rim. Worst case scenario I can swap them out for a wider 6.5" rim.. or 285/75's?
The tires on it now are 33/12.5 15's (which I dislike) and I have a set of Courser bias ply 7.50 16's (might be too narrow)
I think I would like the narrow 7.5's on a stock truck but this thing is a bit of a beast and lends itself to a more aggressive tire.
The rocker sits at 24" and the top of the fender opening is at 40" for comparison.
thanks for your opinions..
66' NAPCO Rescue http://67-72chevytrucks.com/vboard/s...d.php?t=710394
giftshopduane is offline   Reply With Quote
Old 07-09-2016, 01:24 PM   #2
61K10
61K10's Avatar
Re: Yet another tire rim question..
here's a couple of pics of mine. 16x6 rim and 215/85/16 tires. perfect for 6" wide rim. A 235/85/16 would be a little taller and a little wider and fit the 6" rim also. Another pic of 10.50/15 on an 8" rim
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-09-2016, 03:36 PM   #3
jtrichard
THE 235s would be about 3/4" wider and 1-1/4" taller than the 215s
jtrichard is offline   Reply With Quote
Old 07-10-2016, 02:41 AM   #4
Adam1966C10
Adam1966C10's Avatar
This website will help with comparing the different sizes. It gives the overall dimensions in inches. You will have to use the yellow size button at the top because the year tab only goes to 1990.
www.1010tires.com/tools/tire-size-calculator
1966 Chevy C10 short bed stepside
Adam1966C10 is offline   Reply With Quote
