07-08-2016, 09:45 PM | #1 |
Parts/Tools for Eaton H052 '67 Chevy C20 3/4 ton
I have found videos on line with YouTube (like this https://www.youtube.com/watch?v=dRhkYQsAKI4 ). And talked to local NAPA, they have thin wall large sockets but no idea what size, I need to tell them. Chevrolet Truck Chassis Service Manual only gives their tool designation, "J-2222" for example. If you have any part numbers or reference I can find with Supplier it would be GREAT. Help
07-08-2016, 11:32 PM | #2 |
Re: Parts/Tools for Eaton H052 '67 Chevy C20 3/4 ton
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
07-09-2016, 08:29 AM | #3 |
So J-2222 is correct for #/4 ton Chevy/GMC PU's? My question is because I have only seen (via videos) what looks like a large thin wall socket. (I did order another repair manual last night trying to find better details.) Thank you for that assistance, just trying to sort this out some before I go to do the job.
07-09-2016, 11:34 AM | #4 |
Six in a row makes it go...
I'm in the market for one also. That OTC 1929 looks like it might work. On Amazon it says it has 8 tangs, but on OTC's site it doesn't specify other than showing 6.
https://www.otctools.com/products/tu...spanner-wrench Here's a pic of mine showing what happens when you don't use the tool.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
07-09-2016, 12:40 PM | #5 |
Guess I need to pull one of my axles to see what I have? (Got side tracked fixing a tire on wife's Toyota FJ.)
07-09-2016, 02:56 PM | #6 |
Well - I think Amazon has incorrect info with the whole "8-tangs" thing. My truck has six and the tool looks like it has six. The only remaining question is whether the diameters are correct. I'll probably take the risk and order it...
07-18-2016, 07:58 PM | #7 |
Problem is cannot find GM Tool No. J-2222, but newer versions like J-2222-C.
07-18-2016, 08:13 PM | #8 |
http://www.freedomracing.com/j-2222-...ut-wrench.html
"J-2222-C Wheel Bearing Nut Wrench 1929" "6-lug type socket designed to fit the locknuts on '46 and up Chevy and GMC 5200 and 7200 lb axles, 9-3/4" DANA 60, C/K, G, Pvans, 9 3/4 in DANA 60, 10.5" DANA 70, 10.5" GM AXLES" If I read that description this SHOULD WORK, (like Shaky said)? |
07-18-2016, 08:15 PM | #9 |
20' Daredevil (Ret)
Pardon me, but I have to ask: Doesn't the newer tool perform the same task?
07-18-2016, 08:57 PM | #10 |
That is what I was trying to figure-out Stocker. From what I found with tool description with Freedom Racing - it sounds the same.
07-19-2016, 09:25 AM | #11 |
The link I posted is what you're looking for, it has 6 tabs on it.
07-19-2016, 09:57 AM | #12 |
Thank you for that confirmation Project King, much appreciated.
07-19-2016, 01:35 PM | #13 |
No problem, I would of replied sooner but didn't see your thread till this am.
