Old 07-09-2016, 07:52 AM   #1
DieselRat
Quick question on fuel tanks
I've got a 1 ton dually with saddle tanks, its got a new tank on pass side, no tank on drivers. Its going to be getting all new fuel lines as well as a cummins which has fuel lines on drivers side. From the looks of it I can just flip the fuel tank in the brackets and run it on either side? Are they side specific or is there any reason I can't do that?
54 GMC OM617 diesel swap
http://67-72chevytrucks.com/vboard/s...d.php?t=588827
87 Chevy Crew Cab Cummins
http://67-72chevytrucks.com/vboard/s...d.php?t=711157
DieselRat is offline   Reply With Quote
Old 07-09-2016, 08:12 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Quick question on fuel tanks
Not sure what year model your looking at ..lmc shows same tank fits either side on mine...oreillys has new ones for my truck for $113...lmc has it for $99....mine only holds 16 gallons,, you might want to have both tanks..
Old 07-09-2016, 10:14 AM   #3
mongocanfly
Post Whore
If you moved the tank you have I'm not sure if the impact cage will swap side to side..unless you still have the drivers side you might have to find one..
Old 07-09-2016, 10:19 AM   #4
Dead Parrot
One tank can work on either side. The nose of the tank always points forward. I think the brackets can work either side as well. The senders are side specific. The inside sender guts also point to the front. So you could swap your tank to the other side but you will need a new sender.
Don't forget to check for a filler location.
Probably easier to leave the tank where it is and factor that into the new fuel lines.
Dead Parrot is offline   Reply With Quote
