07-09-2016, 03:30 PM | #1 |
NOS cab corners
Is there such a thing? I guessing not, since this wasn't part of the assembly process like a rocker. I've read that the repop cab corners all have to be split and put back together as they are made to slip over instead of replace the original, which doesn't make a lot of sense to me.
07-09-2016, 10:56 PM | #2 |
Re: NOS cab corners
The rear corners are part of the cab back panel. I have used decent fitting corners, but not sure who made them. There are different companies making them. When a panel is the correct dimensions, same size as what you are replacing, the thing to do is step flange. That makes the better job than cheap slip over patches
07-10-2016, 01:48 AM | #3 |
Moderator
Re: NOS cab corners
I butt weld stuff like this stitched up with MIG and copper body spoons where I can get to the backside. It's a skill. Take a scrap fender and slice it with your plasma cutter or cutoff tool then practice workholding and stitch butt welding the seams back together without warping them.
I only lap weld where the factory seam was a lap weld. If you're using body panel adhesives then flanged panels may be the way to go. I'd rather butt weld em. Less filler to smooth it off so less chance of coming back to do it again later after it rusts and bubbles off the paint. Look at the Frankenstein and Bride of Frankenstein threads.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 07-10-2016 at 01:54 AM. |
07-10-2016, 11:35 AM | #4 |
Re: NOS cab corners
Butt welding would be my first choice, but I had read somewhere that all the repop cab corners are made to be slip on and so they won't fit without considerable work. Can't remember where I saw that but I thought it was on here somewhere.
07-10-2016, 12:12 PM | #5 |
Re: NOS cab corners
I can't answer your question but I just recently fixed my cab corners and was pretty disappointed with the fit. I've never purchased patch panels before and didn't realize they were designed to be a slip on....
Splitting them is what I ended up doing. I have pictures of my work if you're interested. Might give you some insight to what you're in for if you need to split them. |
07-10-2016, 02:38 PM | #6 | |
Re: NOS cab corners
07-10-2016, 03:09 PM | #7 | |
Re: NOS cab corners
Inner fit good. It didn't have the hole for the drain but I added one. I didn't feel like drilling all these spotwelds out so I butted it in. http://i.imgur.com/sYUqz6s.jpg http://i.imgur.com/yZh1eln.jpg Here you can see how big the patch was... http://i.imgur.com/UiU64g2.jpg Here's where I decided to split it. I did it here because it's right over top of the inner seam of the inner cab corner. Also it was the width of a piece of masking tape from the edge... http://i.imgur.com/M16x9rW.jpg Tacked in. Took several hours but this thing fit extremely well in the end. http://i.imgur.com/W3ZK8YX.jpg Welded up. http://i.imgur.com/ArBwxJg.jpg Just before filler went on. http://i.imgur.com/io159gD.jpg Here's where I'm at. You can see the filler on the edge that I mention below. http://i.imgur.com/vrHZgr3.jpg I also had to trim a good 1/4" off the lip where it spot welds into the door jamb. I also had to remove a lot where it butts against the rocker. I am a welder but I haven't done a whole lot of body repair but I believe this turned out quite well. Take your time fitting things up and it will go a lot smoother. I used a hand file to really fine tune my seams. I would say the thickest filler is around 1/16", except for on the back corner. The radius is not the same as OEM so I had to blend the patch to the cab with a bit of filler. I tried to get it to match but just didn't have the tools to do so. I got the panels from RockAuto and they were listed as "Goodmark" which I had read good things about, but upon arrival they were "Keystone". The drivers cab corner wasn't as bad so I didn't repair the inside. The patch also seemed to be almost the correct width at the seam, but the bottom was huge. I don't have many pics of this but I split the back of it but only half way just to make it curve like it's supposed to. I split the front a bit to get it to line up a bit better but decided to not go the whole way. As a result it isn't quite straight across the front but it's only where it meets the rocker and I will seam seal that anyways. http://i.imgur.com/VYJ2ars.jpg I hope all that makes some sense. My cellphone camera is pretty bad but you should get the idea |
07-10-2016, 03:15 PM | #8 |
Re: NOS cab corners
That helps a ton, thanks. I was also wondering if you can repair the inner without pulling the carpet, trim, and seat out and it appears that you can. Thanks again.
07-10-2016, 03:18 PM | #9 |
Re: NOS cab corners
Yep I didn't remove any interior pieces. I didn't pull the tank either because I figured I could get away with leaving it in... then I ended up just removing the tank anyways. Wish I had just removed it from the start.
07-10-2016, 09:42 PM | #10 |
Re: NOS cab corners
I recently installed new inner/outer cab corners on my 82. You have to be careful because there are a lot of cheap/thin replacement parts out there. I got my corners from a company called "Key Parts". They are located in the US. I don't think you can get stuff right from Key Parts, you have to find a distributor. I was very impressed with the fit, and the parts were as thick, or slightly thicker than OEM. I butt welded mine in with a Lincoln Mig welder.
