Tie rods
Helping my buddy do his spindle swap and he was told they were from a 1975 c10 but the 1975 tie rods are to big. What year did the tie rods change from 73-87. Also are the ball joints all the same for those years. I knew what year my were which made it easy. Oh and whats throwing me off is the rotors are 1 1/4 5 lug
Thx |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Tie rods
All changes are made by these years.
60-62 63-70 71-72 73-87 Sounds like you have 71-72 spindles?
Re: Tie rods
Which part of the tie rod is too big?
The threaded end? Or the end that connects to the spindle. 63-70 tie rods are 5/8" thread. 71-87 tie rods are 11/16" thread.
Re: Tie rods
Re: Tie rods
You need a tie rod adapter or you need to use a 73-87 centerlink and tie rods.
You also need to swap to 73-87 balljoints. It would have been simple if you had just used 63-70 conversion spindles. They are a direct bolt on.
Re: Tie rods
look at this thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=405330
Re: Tie rods
We are good there he had the whole linkage to 75. Did 1972 spindles accept the d52 calipers? These did and the 1 1/4 inch rotors
Re: Tie rods
Yes
Re: Tie rods
Thx for the replies its appreciated ill try that tomorrow. Last question were the 72 and 75 ball joints the same. Ill be at the parts house tomorrow now that i somewhat have a clue, but they will probably have to order it with his luck.
Thx again |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Tie rods
Np they are not the same.
Re: Tie rods
Captainfab is correct.
The 71-72 upper balljoints are different than the 73-87 version. But the lowers are the same. If you have 1975 parts use 1975 balljoints and tie rods. Including the centerlink and idler arm. (Which will have to be correctly mounted to your frame since it mounts in a different location)
Re: Tie rods
OK looks like you can have a square body suburban thanks for the help guys
#13 |
Re: Tie rods
Dang auto correct . What i meant to type is it looks like he has 1991 suburban spindles.. Thank yall
#14 | |
Re: Tie rods
In 1992 the suburbans got the 88-98 truck parts.
#15 |
Re: Tie rods
thx for the replies . I dont know what he got and i dont think the guy he got them from knows either. i am just gonna pull a fresh set for him so i know everything matches. Any body made a template of where to place the idler arm. I still got to do that on mine.
Thx for replies Chris |
