Old 07-10-2016, 12:40 PM   #1
spookylynx
spookylynx's Avatar
bulb for front turn signals
Anyone off hand know the bulb # for the front amber lights? '65 Chev.
spookylynx is offline   Reply With Quote
Old 07-10-2016, 01:23 PM   #2
jtrichard
Re: bulb for front turn signals
1157 or 1034 IF you want the bulbs to be amber then they would be 1157A and 1034A
jtrichard is offline   Reply With Quote
Old 07-10-2016, 10:14 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Hmmm, I thought the rear was 1157 and front were 1156. Am I wrong guys??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-11-2016, 12:19 AM   #4
jtrichard
1156 is a backup type bulb ....Only has ONE filament.... The front on our trucks is a combo park and turn 2 filament light
Old 07-12-2016, 09:00 AM   #5
spookylynx
spookylynx's Avatar
Thanks!
Old 07-20-2016, 12:46 AM   #6
Bart Savage
Bart Savage's Avatar
whats the difference between the 1157 and the 1034??
Bart Savage is offline   Reply With Quote
Old 07-20-2016, 01:26 AM   #7
jtrichard
By David Sandoval, eHow Contributor
Automotive lamps burn out after a long period of use. Often, more than one bulb can serve as a replacement part for nearly any automotive lamp. For example, an 1157 automotive lamp is electrically compatible with a 1034 lamp. However, some notable differences between the two lamps may make one better than the other for your specific situation.
Primary Filament Operation at 12.8 Volts
The primary filament is used for normal marker-lamp (the rear light that comes on when you turn on your headlights) operation. The 1157 lamp can sustain 2.10 amps at 12.8 volts, and will last an average of 1,200 hours. The 1034 lamp can handle 1.80 amps at this voltage, and will last an average of 200 hours.
Secondary Filament Operation at 14 Volts
The secondary filament is used for turn signal operations. The 1157 lamp can sustain 590 milliamps of electrical current at 14 volts, and lasts an average of 3,000 hours. The 1034 lamp lasts an average of 5,000 hours under these conditions.
Considerations When Choosing Which to Install
Since both lamps are used as combination turn-signal and marker lamps, choose the lamp that suits your needs best. If you do a lot of daytime driving and require a long-lasting signal lamp, install the 1034 lamp. If you do a lot of nighttime driving, and do not need to use your turn signals often, choose the 1157 lamp.
