Old 07-10-2016, 09:32 PM   #1
cyclonewade
Brake lamp switch stock pedal
Does anyone have any pictures of the brake light/lamp switch on 3100 48-54 using stock pedal? My firewall has two little holes where I believe a mechanical actuated switch once lived.
Thanks.
cyclonewade is offline   Reply With Quote
Old 07-10-2016, 11:02 PM   #2
nvrdone
Re: Brake lamp switch stock pedal
don't have a picture but check classic parts. p/# 53-011 $5.95
nvrdone is offline   Reply With Quote
Old 07-11-2016, 01:25 AM   #3
mr48chev
mr48chev's Avatar
Stock switch mounts on the outside of the kick panel below the steering column and the brake pedal arm works the lever on the switch. It's held by two machine screws that go though the floor below the column and is is a two person job to install unless you have the worlds longest arms.
My ongoing truck projects:
Old 07-12-2016, 05:42 AM   #4
hogfarm
My local NAPA had one in stock
hogfarm is offline   Reply With Quote
Old 07-12-2016, 04:05 PM   #5
mr48chev
mr48chev's Avatar
As my neighbor over the hill said Napa lists them.
https://www.napaonline.com/napa/en/p...128_0240268567
O'Reilly's shows one too http://www.oreillyauto.com/site/c/de...2071&ppt=C0039
From the Rock auto page a couple of parts numbers are Standard motor products sls43 and AC Delco D866C The Delco number should cross at any parts house.
