Old 07-10-2016, 10:32 PM   #1
68longhorn
68longhorn's Avatar
When is c notch required?
Right now my 86swb has a leaf removed for a mild drop, but its not low enough. How low before a c notch is required. Or does the truck tell you by bottoming out?
1986 Custom Deluxe 10
1978 Caprice 2 door - sold
1937 Chevrolet 2 door sedan - project
68longhorn is offline   Reply With Quote
Old 07-10-2016, 10:44 PM   #2
SkinnyG
SkinnyG's Avatar
Re: When is c notch required?
You won't really need one, even with a flip. With a notch, the pumpkin hits the bed floor before the axle tubes will. With bumpstops removed, I'm not sure what would hit first - the pumpkin or the tubes - it's be close.
I notched mine when I flipped the axle, but I don't think it's necessary.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-11-2016, 04:07 AM   #3
bbbc10
Diggin The SquareLife
If you dont plan on hauling anything or towing anything you can go low as 6" drop with no notch and if you plan on that anything more than 4" drop you will need one....i did 6" flip kit with notch.....but didn't need it since i never hauled or towed with it.
bbbc10 is offline   Reply With Quote
Old 07-11-2016, 12:52 PM   #4
SkinnyG
SkinnyG's Avatar
I've had 1700lbs of sand in the back of my truck, with a flip on heavy 8-leaf pack. Box floor sitting on the pumpkin, axle tubes ~still~ not into the frame notch I cut.
Though - riding low, cornering, ~and~ hitting a bump - the notch might be needed, since on a one-wheel bump that end may want to move higher than the frame rail.
If I were to do it again, I would NOT notch the frame, and "try it and see" if I actually need one.
Old 07-11-2016, 02:18 PM   #5
BShort
I agree with previous posters. Lower it until you are happy and THEN decide if you want/need the notch. You can probably go as low as you want and not ever require the notch.
BShort is offline   Reply With Quote
Old 07-12-2016, 08:26 PM   #6
68longhorn
68longhorn's Avatar
Thanks guys. Now to save for a drop
Old 07-12-2016, 09:57 PM   #7
RootBeerFXS
RootBeerFXS's Avatar
Just drove 4k miles on the Hot Rod Power Tour with a flip and a shackle. The tubes hit only on sharp bumps but not the pumpkin. I have a new 4 leaf pack as well. I had about 150 lbs in the bed and 550 lbs of rednecks in the cab.
RootBeerFXS is offline   Reply With Quote
