Old 07-10-2016, 11:33 PM   #1
60burb4me
rubber mat for 60 burb
just built the floor for my suburban anybody know where to get the rubber mat?
60burb4me is offline   Reply With Quote
Old 07-11-2016, 10:25 AM   #2
MitchFloyd
MitchFloyd's Avatar
Re: rubber mat for 60 burb
If it's a low hump then any vendor will have it. LMC / Classic / Brothers ...etc.
If it's a High hump then either the MIP rubber mat or carpet. No high hump mats are being produced.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 07-12-2016, 12:03 AM   #3
60burb4me
thank you but I am looking for the rubber that goes on top of the wood floor in the back of the suburban.
Old 07-12-2016, 07:48 PM   #4
MusicMan70
MusicMan70's Avatar
Those look to be vinyl and I don't think they are reproduced. Perhaps something from here;
http://www.tractorsupply.com/tsc/pro...d?cm_vc=IOPDP1
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-12-2016, 09:28 PM   #5
60burb4me
the photo I showed you had wood flooring on it it was just to show where I needed it at. The link you sent me might work I will have to take some Measurements I am not sure if 4 ft wide is wide enough. thanks for the help
Old 07-12-2016, 09:33 PM   #6
60burb4me
here is what I need to cover
Old 07-12-2016, 09:35 PM   #7
66 Burban
66 Burban's Avatar
4 ft is not wide enough --- that's why the orig wood floor is in 2 pieces...
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 07-12-2016, 11:48 PM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
also, the original mat is glued to the wood floor, so you will not be able to use an og one if you find one in a sub.
Old 07-13-2016, 12:30 AM   #9
60burb4me
thanks I will take measurements when I can I am going to cover with carpet anyways. Has anyone else used anything else?? I was seriously thinking about just using dynamat?
Old 07-13-2016, 02:07 AM   #10
jonzcustomshop
1961 crewcab
seems like if you were set on rubber a fleetside truck rubber bed liner mat might work
