Old 07-11-2016, 02:42 PM   #1
Mrturner1
Anybody build there own exhaust using these?
Do these things work pretty good? No leaks or anything bad like that? I'm putting together a new exhaust for my truck to replace the old 2 1/4" that's on it now
Mrturner1 is offline   Reply With Quote
Old 07-11-2016, 02:43 PM   #2
Mrturner1
Re: Anybody build there own exhaust using these?
Pic
Old 07-11-2016, 03:12 PM   #3
BrianG
BrianG's Avatar
My 2006 GMC Envoy has one of those on it. It's been good for 200,000 miles.
BrianG is offline   Reply With Quote
Old 07-11-2016, 10:23 PM   #4
Grandpa54
Grandpa54's Avatar
Yes
Grandpa54 is offline   Reply With Quote
Old 07-11-2016, 11:43 PM   #5
Boyd67
Boyd67's Avatar
I had about a $900 exhaust on my SRT4 and after about a year the flex pipe started tearing which of course caused a exhaust leak. I'm not saying yours automatically will but they do tear. So good luck my man
Boyd
-67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie
Boyd67 is offline   Reply With Quote
Old 07-12-2016, 12:13 AM   #6
Gmc.guy
Gmc.guy's Avatar
Brand quality may differ. I have seen one on a stationary Cummins with a solid mounted vertical stack on a sawmill. Must have been 4 or 5". I noticed it shaking into a Z shape at idle and a good bend at balls out. Can't say much for how long it lasted but definitely high abuse for sure
-Cody
Gmc.guy is offline   Reply With Quote
Old 07-12-2016, 04:51 AM   #7
Mrturner1
This is what I was expecting because the thing is almost too good to be true lol
Old 07-12-2016, 05:21 AM   #8
scooterpimp
scooterpimp's Avatar
Used one on my work car to replace the factory pipe was $171.00 or buy flex joint & cut & weld in for $24.00. Guess which one i chose to do...still good after 6 months & 14k. Miles...they have these @advanced , auto zone etc.
scooterpimp is offline   Reply With Quote
Old 07-12-2016, 07:33 AM   #9
Grumpy old man
Grumpy old man's Avatar
Where would you need to use these on your exhaust ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-12-2016, 08:19 AM   #10
biketopia
Yea you shouldn't need a flex pipe in your system, rubber mounts on your hangers and you're good to roll.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 07-12-2016, 11:48 AM   #11
midniteblues
midniteblues's Avatar
They are not a bad idea,certainly not nessacary.
I'm sure they will help too keep those header bolts good and tite.
Quality matters here.
I had bought two when I built my exhaust since my headers exit at slightly weird angles I figured these would help with that.
But I didn't end up using them anyway and returned them.
They were store brand like walker or something and not good quality either.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 07-12-2016, 01:17 PM   #12
72kool
72kool's Avatar
as others have said, brand quality makes the biggest difference in how long they last. While you can use them in your exhaust system, im not sure the need you would have for them on your truck. the reason they exist and are used is for side mounted engines on fwd vehicles. the idea is that engines rock side to side under acceleration and a solid exhaust system would break over time or the first time you floored it depending on the vehicle. These flex pipes allow the engine to move while limiting movement of the exhaust system. On a rear wheel drive vehicle like our trucks, rubber lined steel hangers are more than efficient in allowing the needed flexibility.
1972 GMC C20 Custom Camper 350/TH350
72kool is offline   Reply With Quote
Old 07-12-2016, 01:26 PM   #13
72kool
72kool's Avatar
https://www.summitracing.com/parts/wlk-36516/overview/
theses are what i recommend for exhaust hangers. they have a clean look to the system without a bunch of pipe clamps at every one, and last the longest in my experience. this is all i like to use on all the custom exhaust i do in my shop. all while providing proper movement for the system
Old 07-12-2016, 06:33 PM   #14
Mrturner1
I'm planning for 3" and I'm not sure really how I'm going to route it yet. I was thinking of cutting a hole in the crossmember to keep the pipes high up off the ground but I don't know how I feel about that yet
Old 07-12-2016, 06:52 PM   #15
Grumpy old man
3" is too much try 2 1/2 , lots of guys cut thru the cross member
Old 07-12-2016, 07:03 PM   #16
72kool
72kool's Avatar
Building your own exaust can be a lot of fun and rewarding. There are a lot of different options on how to route it on these trucks depending on what drivetrain you have. Before you decide what your going to do, I would evaluate everything to make sure you get the most from your exhaust. What engine do you have? What is your goal for this project? 3 inch may be too big and disappoint you.
Old 07-12-2016, 09:09 PM   #17
Mrturner1
It's a 70' c10 LWB, lowered just an inch or two but may go lower later. 10-1 355cid big cam (comp 280H) big stall (3000), th400 and 3.73 mini spool, Holley 750 DP, basically a fun truck to roast tire in when I get home from work on the weekends, and one day when I feel that the suspension and brakes are safe enough I'll take it to the track. Ultimate goal is to get her into the 12's, I'd be a real happy camper if I did that!
Watched quite a few dyno tests and all they changed was the pipes, 2.25" lost some top end to the 2.5" and 3". The 2.5" and 3" performed almost exactly the same except the 3" made a few more ponies waaaay up top. The 3" did not loose ANY low-mid range to either the 2.5" or 2.25". All this was done on a 400hp 9.5-1 383 stroker
I'm real tempted to build an X-pipe too, saw some great results from those on SBC's
Old 07-12-2016, 09:36 PM   #18
MikeB
MikeB's Avatar
Probably because the best exhaust pipe you can have behind long tube headers is NONE.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 07-13-2016, 02:24 AM   #19
Billhilly
Billhilly's Avatar
Yes. I put them right behind the headers, mine are about 7" long on a 2 1/2" pipe set up. I've only done about 4500 miles, but so far so good. Lots of modern cars/trucks have them. Hoping to isolate the headers from any excessive loads.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 07-13-2016, 11:40 AM   #20
MikeB
MikeB's Avatar
Good idea. Nice chassis.
Mike
Old 07-13-2016, 11:44 AM   #21
Gmc.guy
Gmc.guy's Avatar
I think that red cherry bomb dodge that was on Gears, or maybe Trucks? Had them on each side but I think it was to make them huge pipes shake on each side that stuck out by the steps
-Cody
